a couple of things with the binding , old firmware that work should it still work, ie backwards compatibility ?
if the fields appear in the log with warnings from the binding , there supported after all its a simple text field ? or would the system bail as there are a few unknown elements ?
[ the fields of information look pretty sane , and could be tweaked ? ]
not sure where to ask this, what is to be supported, all we can ?, a selection of firmwares or just the latest firmware/equipment ?
Hi All, trying to get the the Gen 1 double dimmer to be registered, have seen 3x new devices in paper ui so have added them but when i try to link/pair them they just dont seem to pairā¦
The device shows a .1 .2 and .6 - the latter does not create a switch in paper ui.
I have however created switch/sliders for all three in basic ui but still cant get it to pair - any ideaās?
I have the lightwave hub working with power sockets and relays only. I will find the lightwave binding version when home. I have a rfxcom unit on the way and hopefully compare notes
Ah, yes and no. The id can be anything, you just need to make sure when your ready to pair the item you just need to put the device into leaning mode - trigger the switch relating to that device via paper or basic ui and then that device will take the associated id.
Took me time to remember how
So - i chucked any id in to get the device paired (manually created thing):
as far as i know only gen1 are supported partially 70%, thats as you said gen2, I dont know if there are any workarounds ifttt/tasker/webhooks to get some control back to openhab
Iām working on this today (not binding) as no one seems to be developing it and I donāt have that kind of knowledge at the mo. Iām using http to control it
Once Iāve got a working solution Iāll post it up,
So far I can authenticate, check energy usage and status. Just working on the actual switching at the mo.
Should have it working by the end of the day.
Iād be very interested to see how you do this and to replicate it here. Plenty of both gen 1 and gen 2 Lightwave stuff here being controlled by the Lightwave Gen 2 hub. Also plenty of Openhab. If I could just interconnect the twoā¦
Iām very close(got a bit stuck with the exec binding), I only have gen2 sockets connected to my gen2 hub so donāt know if my solution will work for everyone but it should give everyone enough code to implement other stuff.
Bear in mind Iām doing this entirely with a rule for initial setup (prob would have been quicker to learn how to write a binding )
I got a couple hours left of coding and should be ready to publish to the worldā¦ hopefully thatās tonight
iāve got it working however it seems to be crashing quartz/cron timers, hence i deleted my post.
ill try and debug tonight.
iāve got switches / power and energy in it at present.
