Another beginner here and I have a few issues with sending commands to my LightwaveRF Link.
It appears to connect at openHAB startup with no problems:
2016-03-04 09:33:02.024 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[room=2, device=1, type=SWITCH] Room[2] Device[1] Serial[null] Type[SWITCH] Poll[-1]
2016-03-04 09:33:02.027 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[room=1, device=2, type=SWITCH] Room[1] Device[2] Serial[null] Type[SWITCH] Poll[-1]
2016-03-04 09:33:02.030 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[room=1, device=1, type=SWITCH] Room[1] Device[1] Serial[null] Type[SWITCH] Poll[-1]
2016-03-04 09:33:02.068 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: IP[LWLINK_IP]
2016-03-04 09:33:02.070 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: ReceivePort[9761]
2016-03-04 09:33:02.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Port[9760]
2016-03-04 09:33:02.074 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Register On Startup[true]
2016-03-04 09:33:02.076 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Delay [100]
2016-03-04 09:33:02.078 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Timeout for Ok Messages [500]
2016-03-04 09:33:02.110 [INFO ] [l.internal.LightwaveRfWifiLink] - Starting LightwaveRfWifiLink Connection
I have configured my .items, .cfg and sitemap so that if I turn a switch on from the Lightwave app it is reflected in openHAB and get this message:
2016-03-04 09:38:49.575 [INFO ] [.l.internal.LightwaveRfBinding] - Update from LightwaveRf ItemName[Light_GF_Living_Table], State[ON]
2016-03-04 09:38:49.589 [INFO ] [runtime.busevents ] - Light_GF_Living_Table state updated to ON
2
Which all looks fine so far.
However, when I turn the switch on from openHAB, nothing happens and I see this
2016-03-04 09:40:59.214 [INFO ] [runtime.busevents ] - Light_GF_Living_Table received command ON
2016-03-04 09:40:59.526 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-03-04 09:40:59.691 [INFO ] [.b.l.i.LightwaveRFSenderThread] - Ok message not received for 200,!R1D2F1
, retrying again. Retry count 2
I’m also seeing these occasionally, which I assume to be the same problem.
[INFO ] [.b.l.i.LightwaveRFSenderThread] - Ok message not received for 100,!F*p
I’ve looked through all the posts that seem to relate to these errors but nothing seems to work.
I’m running openHAB 1.8.1 on a Raspberry Pi 2 B and have a z-wave daughter board installed, although nothing is configured to that at the moment.
I’m pretty sure its something simple I’ve overlooked but can’t work out what ! Any help would be appreciated.
Alan
