I’ve installed the 1.8.0 addon. What type= name are you using for the output? I guessed at OUTPUT but I didn’t get anything in the log and the parameter shows uninitialized in openHAB.
Number RadiatorOutput “Radiator Output [%.1f %%]”(Radiators) { lightwaverf=“room=7,serial=F05102,type=OUTPUT” }
On the subject of the Home Thermostat, I installed one today. Not sure of the best way to let you see the messages so these are from the openHAB log:
2015-12-09 20:13:43.933 [ERROR] [l.internal.LightwaveRfWifiLink] - Error converting message: :033D0F,256,!R2F*s=N5,B25,Y10,T19,S07:00:00,E08:30:00,T19,S17:00:00,E20:00:00
This is a schedule setting message. The 033D0F seems to be the unit serial number. N5 is day of week 5. Y is the setback temperature (ie the temperature when the heating isn’t on). After that are groups of schedule: T19 = temperature 19, S07:00 is start at 07:00. E08:30 is end at 0830.
2015-12-09 20:13:42.999 [WARN ] [.l.internal.LightwaveRfBinding] - No item for incoming message[*!{“trans”:6544,“mac”:“03:3D:0F”,“time”:1449692023,“prod”:“tmr1ch”,“serial”:“D76C02”,“signal”:47,“type”:“temp”,“batt”:3.26,“ver”:33,“state”:“run”,“cTemp”:19.9,“cTarg”:20.0,“output”:0,“nTarg”:18.0,“nSlot”:“22:00”,“prof”:3}]
Not sure what triggers this update. cTemp is the current temperature, cTarg is the current target. output is whether the stat is calling for heat. nTarg is the next target temperature and nSlot is the start time of the next slot.
2015-12-09 20:13:43.802 [ERROR] [l.internal.LightwaveRfWifiLink] - Error converting message: :033D0F,100,!F*p
Not sure what this on is.
2015-12-09 18:39:20.557 [ERROR] [l.internal.LightwaveRFReceiver] - Error converting message: :033D0F,250,!R2DhF*r|Requesting|Temperature
Looks like this one is the call for an update.
If you’re interested in adding this to the binding, let me know and I can do some more experimenting.
