Yes. After clearing the cache you get the distribution Version.
ok, thanks for the hint. But after update to:
update org.openhab.binding.amazonechocontrol https://janessa.me/esh/org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar
i cannot access the amazonechocontrol
and it says
Thing ‘amazonechocontrol:account:6c171fb8’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
But that snapshot JAR isn’t even available anymore, if I’m not mistaken. Try going to https://janessa.me/esh/org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar with your browser and it says no longer available.
That may explain, why nothing worked after the update.
Are there any suggestions to resolve the issue?
[ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@1921ebf’: GET url ‘https://alexa.amazon.de/api/behaviors/automations?limit=2000’ failed: Not Found
Is there an updated download link? That one doesn’t work anymore
Weird, extracted the JAR from " 3.1.0~S2222/", placed it into the addons-folder, but still have the same error.
did you check which binding is the active one ?
in the openhab karaf console run:
bundle:list | grep -i amazon
Thank you, stopped the old one and activated the 3.1.0 one and now it works.
I downloaded the jar file to the addons folder.
How do I activate it?
after restart of OH service the binding should be visible in the karaf console and you should see if it is activated.
I run the command
And got empty answer…
You are on OH3 ? The owner of the jar file is user openhab and group openhab ?
This is OH3.
The output of ls -l of addons folder:
-rw-rw-r-- 1 openhabian openhab 466281 Apr 1 08:14 org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar
Do I need to change the owner from openhabian to openhab?
Does anyone have a current link for the updated addon? The two links mentioned in this thread no longer work.
The links no longer work.
Is there another way for a normal user to get the file?
I was still using 2.5.10-1
Thanks!
You can try to download the 2.5.12 addons kar file https://repo1.maven.org/maven2/org/openhab/distro/openhab-addons/2.5.12/openhab-addons-2.5.12.kar and extract the addon ( jar file ) from this kar file.
I do not know if 2.5.12 addon is compatible with your 2.5.10-1 instance.
