//Power Lights/Aircon/Oven calculation
rule "Power sum1"
//Item PWR_I2 received update or
Item PWR_I3 received update
var Number power2=PWR_I2.state
var Number power3=PWR_I3.state
postUpdate(PWR_Isum1, (power2 - power3))
var Number myNow = now.millis
var Number myMidnight = now.withTimeAtStartOfDay().millis
logWarn("test","-----------")
var Number minsSinceMidnight = ((myNow - myMidnight)/1000)
var Number avPowerA = (PWR_I2.averageSince(now.toDateMidnight, "rrd4j")).format("%.2f")
logWarn("average power today",avPowerA.toString)
var Number avPowerkw= avPowerA * 235
avPowerkw=avPowerA / 1000
logWarn("kW on average",avPowerA.toString)
//Convert kW to kWh
var Number avPowerKwh = (avPowerkw.toString*(minsSinceMidnight/60)).format("%.2f");
logWarn("test",avPowerKwh.toString)
//postUpdate(PWR_UseTodayKW,avPowerKwh.toString)
Here is the response:
2016-10-03 00:54:41.159 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Power sum1’: Could not invoke method: org.openhab.model.script.lib.NumberExtensions.operator_multiply(java.lang.Number,java.lang.Number) on instance: null
I have other rules working with more complexity than this, but can’t seem to make this work.
Also make sure all of your Item’s actually have a state and are not undefined.
Double check that everywhere you get a Number Item’s state you cast out to DecimalType.
Make sure to have a hard look at your calculation of avPowerKwh. It looks like you are trying to use String formatting to round the value, which will not work. Do the rounding stuff.
Solved the issue by removing the string formatting .format() stuff and casting all numbers out as decimalType. Very happy!
Here’s my working rule:
rule “Power sum1"
logWarn(“test”,”-----------")
var Number step1rate = 0.21384 //in dollars
var Number step2 = 6.57532 //in Kwh
var Number step2rate = 0.24662 //in dollars
var Number power2=PWR_I2.state as DecimalType
var Number power3=PWR_I3.state as DecimalType
var Number minsSinceMidnight = ((myNow - myMidnight)/60000)
logWarn("Time since midnigh",minsSinceMidnight.toString)
logWarn("average power since midnight",avPowerA.toString)
var Number avPowerkw= (avPowerA * 238) / 1000
logWarn("kW on average",avPowerkw.toString)
//Convert kW to kWh
var Number KwhUsedToday= (avPowerkw * (minsSinceMidnight/60))
logWarn("Kwh used today",KwhUsedToday.toString)
//Calculate costs
var Number myCost = 0
if(KwhUsedToday>= step2) {
//Greater than step2, 2 step pricing
var Number myDifference = KwhUsedToday - step2
myCost = ((step2 * step1rate) + (myDifference * step2rate))
} else {
myCost = (KwhUsedToday * step1rate)
logWarn("My cost",myCost.toString)
postUpdate(PWR_UseTodayKW,KwhUsedToday.toString)
postUpdate(PWR_CostToday,myCost.toString)
