I have several new GoControl branded Linear WD500Z5-1 Dimmer wall switches that are showing up as device unknown. These switches show up on the zwave device list. I am running Openhab 2.4 release build and the zwave binding 2.4 release as well. Any ideas? Thanks in advance for the help. Here is the XML file: network_c67018ed__node_80.xml (10.7 KB)
Your device is in the database so should be detected. Probably you just need to use a more up to date binding.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/885
