I have a Somfy Wirefree windsensor. This does close my awning automatically and in somfys own app generates a ‘warning’ flag. Is there a way to link this sensor to an Item in openhab?
I thought about creating a rule as an alternative. Problem I can’t get my head around at the moment is the fact that we also control the awning by remote. So if the awning received a command UP (or position changed to 0%) and this command/change was not generated by a rule, I still can’t distinguish between the remote and windsensor…
Maybe someone came around the same issue and sorted it out? That would be fantastic!
That would be useful information
I am using the Somfy Tahoma binding 2.3.0 SNAPSHOT. This does control the awning. But can’t find the configuration to the windsensor (not in the INBOX)
I don’t know that binding but from reading recent posts, I don’t think the wind sensor is integrated in the binding. But I could be wrong. Check other posts.
Another solution you be to get the output of the wind sensor in parallel to an ESP8266 talking mqtt to OH.
