I have a dimmer to follow a itemswitch that works dimmer goes to 100% when itemswitch is on.
Can someone help me so the dimmer goes to 12% from when itemswitch is ON
Two options I can think about right now:
1st via rule:
Do not link the dimmer item to the switch channel
Have a switch item linked to the switch channel
Create a rule, when the switch item will change to on, that the dimmer will go to 12%
2nd via profile:
Keep the dimmer item linked to the channel
Within the channel-item link: Instead of using the standard profile use a custom profile (e.g map transformation, needs to be installed separately first) to convert ON/100% to 12%
// Possible rule solution
rule "LinkedDimmer"
when Item itemswitch changed to ON
dimmer.sendCommand(12)
