That’s good
Finally have everything working properly. I cross linked each Insteon device back to the Insteon modem to get the devices to send state updates back to OH2. The issue I kept fighting was the logic worked fine when controlling via the BasicUI or the iOS app. When manually switching ON the wall switch (A), module (B) would immediately follow the ON command then power OFF within a second. A manual OFF command and module A switched OFF and module B stayed OFF.
During all the debugging, I cross linked the Insteon modules to each other see if that had an impact. Once I removed the cross linking between module A and B, the logic works perfectly both manually and via BasicUI.
