Hi guys,
since yesterday, after I cleaned the cache and temp, and restarted OH2, the links between my Items and MQTT channels are getting removed. Thus, I cannot retrieve any MQTT messages anymore. The log shows following:
**2020-11-29 19:38:37.521 [temChannelLinkRemovedEvent] - Link 'Maestro_Power_Level => mqtt:topic:Maestro:mczStatus' has been removed.**
2020-11-29 19:38:37.524 [temChannelLinkRemovedEvent] - Link ‘Maestro_Fan_State => mqtt:topic:Maestro:mczStatus’ has been removed.
2020-11-29 19:38:37.527 [temChannelLinkRemovedEvent] - Link ‘Maestro_Control_Mode => mqtt:topic:Maestro:mczStatus’ has been removed.
2020-11-29 19:38:37.529 [temChannelLinkRemovedEvent] - Link ‘MyMaestro_ECO_Mode2 => mqtt:topic:Maestro:mczStatus’ has been removed.
2020-11-29 19:38:37.531 [temChannelLinkRemovedEvent] - Link ‘Maestro_Text_Raw => mqtt:topic:Maestro:mczStatus’ has been removed.
2020-11-29 19:39:30.123 [hingStatusInfoChangedEvent] - ‘mqtt:broker:MqttBrokerMcz’ changed from UNINITIALIZED to INITIALIZING
2020-11-29 19:39:30.282 [hingStatusInfoChangedEvent] - ‘mqtt:broker:MqttBrokerMcz’ changed from INITIALIZING to OFFLINE
2020-11-29 19:39:32.207 [hingStatusInfoChangedEvent] - ‘mqtt:broker:MqttBrokerMcz’ changed from OFFLINE to ONLINE
2020-11-29 19:39:32.240 [me.event.ThingUpdatedEvent] - Thing ‘mqtt:broker:MqttBrokerMcz’ has been updated.
2020-11-29 19:39:34.982 [hingStatusInfoChangedEvent] - ‘mqtt:topic:Maestro’ changed from UNINITIALIZED to INITIALIZING
2020-11-29 19:39:35.113 [hingStatusInfoChangedEvent] - ‘mqtt:topic:Maestro’ changed from INITIALIZING to ONLINE
To the configuration:
All my things, channels and items are configurated using files. After I got this problem, I’ve upgraded to the newest stable branch via openhabian-config. Openhab2 is running on openhabian (rasp4).
I can still “send” MQTT messages (pressing a switch), but receiving seems not to work. Also when I add a new item, and link it to the same channel, it is not working. I’ve restarted Openhab 2-3 times since yesterday. Sometimes the items where missing, now, the items are there, but still no MQTT message is retrieved…
Some Ideas what’s going wrong here?
