I have an item that is a string and it’s the ip address of my device. Is there a way to make the item in the location cars a clickable link to the devices webpage?
I believe they the only way you will be able to do this is to modify the default widgets for this item. You can create your own widgets where you use any of the components that accept actions to link to a custom URL.
If you are not familiar with customizing the default widgets for an item, this section of the getting started tutorial will be helpful:
