Based on the output that you posted it can be concluded that the service lircd is running.
No sorry.
Now i reboot all and i post the situation
here the situation after the reboot
the lircd service is failed.
If i want start it i have to activate manually
As long as the service is not started after booting - what is returned by
sudo systemctl status lircd.service
So we are again arrived at the same question as before.
Is the listen address/port for the service already in use ?
i think no.
how can i control it?
I dont’ understand.
If i turn on LIRC manually without problems, why doesn’t LIRC service start automatically at the reboot?
I tried to create e bash script so:
#!/bin/bash
### BEGIN INIT INFO
# Provides: avvio_lirc.sh
# Required-Start: hal
# Required-Stop:
# Should-Start:
# Should-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Avvio automatico LIRC
# Description: Avvio automatico LIRC
### END INIT INFO
/etc/init.d/lircd start
exit 0
i activate all so
sudo chmod +x /etc/init.d/avvio_lirc.sh
sudo systemctl enable avvio_lirc.sh
sudo update-rc.d avvio_lirc.sh defaults
I solved by delaying the execution of the start command in the script by the command sleep 20
#!/bin/bash
BEGIN INIT INFO
Required-Start: hal
Required-Stop:
Should-Start:
Should-Stop:
Default-Stop: 0 1 6
END INIT INFO
sleep 20
exit 0
Thank’s anyway
