Hi
i have a problem with the LIRC.
I control my tv with LIRC but averytime that i reboot the Rasberry i have to start LIRC.
Is there a way to start LIRC automatically on every reboot of the raspberry?
Thank’s
Have a lookt at the description of the lirc binding . If your OS is systemd based you can follow the description under the headline “Supported Things”.
i tried but i have not the file /usr/lib/systemd/system/lirc.service
Maybe the path is wrong
How did you install lirc ? How do you start lirc manually ?
yes.
but LIRC works but i have to lunch it by the command
sudo /etc/init.d/lircd start
it doesn’t start automatically
Maybe there is a config file to modify to start automatically
this is already the file that needs to be used during system boot.
please use the command
find /etc -name "*lirc*"
to check if a link to the related boot levels is established.
There should be links in /etc/rc*.d/ pointing to /etc/init.d/lircd. If that is not the case try to run
update-rc.d lirc defaults 20
to create the links.
The message/error “could not assign address to socket” normally means that the port that is used in the lirc configuration / startup file is in use already.
Check the configuration / startup file which port is being used by lircd.
Then execute
lsof -p :port
replace “port” with the port number that is used in the configuration file.
As a result the process that uses the port will be shown.
It’s either an other service or the lirc daemon is already running.
Hi
it is not the problems. That message of error is because i stopped LIRC by the command “sudo /etc/init.d/lircd stop”
I explain you:
I use normally LIRC and it works but if i reboot the rasberry then i have to activate LIRC by the command “sudo /etc/init.d/lircd start”.
The problem is that i’d like LIRC start automatically when i reboot the rasberry.
I tried to do so:
Sudo nano /etc/rc.local
And into the file i inserted the command to start lirc: sudo /etc/input.d/lircd start
Then i reboot all by the command sudo reboot but again if i want lirc starts i have to digit the command to start lirc (sudo /etc/input.d/lircd start)
How do you do it?
help me pls
How did you install lirc ( e.g. via package manager ) or from source ( e.g. github ) ?
Github
From which location on github / which url ?
Is there any logfile with lirc in it’s name in directory /var/log/ ( ls /var/log/lirc ) ?
Is there any entry in /var/log/syslog that contains the string lirc ( sudo grep -i lirc /var/log/syslog ) ?
I don’t remember
Is there any logfile with lirc in it’s name in directory /var/log/ ( ls /var/log/ lirc ) ?
yes
Google is your friend. Please check the following tutorial, as this is not an openHAB or openHABian related issue.
You wrote that there are entries that are related to lirc in syslog. What is the content ? What is the message of these entries ?
Now i again digit the code "sudo grep -i lirc /var/log/syslog but i have nothing.
Maybe because yestarday i lanched lirc and today no
What do get back for ( do not manually start the service )
sysv-rc-conf --list | grep -i lirc
and
systemctl list-units --type service --all | grep -i lirc
