List Item Widget for Freebox server [4.0.0.0;5.1.9.9]
This is an UI List Item Widget to view the Freebox server information with the FreeboxOS Binding.
Only use with List Card with accordion and rich list items option set to true.
Support to use a light and a dark background.
Configuration parameters:
  • All title string
  • All Icons - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
  • Visibility of List item
items
  • Line Status item
  • Uptime item
  • Temperature CPU AP item
  • Temperature CPU Master item
  • Temperature CPU Slave item
  • Temperature HDD item
  • Temperature 1 item
  • Temperature 2 item
  • Temperature 3 item
  • Fan 1 item
  • Fan 2 item
  • Bandwidth Usage Down item
  • Download Rate item
  • Bandwidth Usage Up item
  • Upload Rate item
  • wifi item
  • Air media item
  • UPnP AV item
  • FTP item
  • Windows File Sharing item
  • Windows Printer Sharing item
  • Reboot command switch item
Screenshots
Screen4
Changelog
Version 0.1
  • initial release
Resources
https://raw.githubusercontent.com/sebSmarthome/openHAB3-widget/main/List_Item_for_use_with_List_Card/Freebox_Server_List_Item/frs_FreeboxServer_Info_list_item.yaml
