List Item Widget for System info [4.0.0.0;4.9.9.9]
Hello, I’m glad you like this widget
In addition, the storage size is not displayed in GB. Do you have any idea what I’m doing wrong here?
Maybe I also need to add something to the metadata here?
set Item metadata unit to GB and set Item Metadata: stateDescription Pattern to %.2f %unit%
but the operating time is not displayed in days, hours and minutes, but only in minutes, not as shown in your screenshot.
set Item metadata unit to min and set Item Metadata: stateDescription Pattern to use this JS transformation
exemple : JS(config:js:78b97e3b17:fr):%s
Javascript transform function to change the number
of minutes of CPU time from the System Info Binding
into a more readable format
eg: 2365 into '1 day 15 hours 25 minutes
(function(i) {
    if (i == 'NULL') { return i; }
    if (i == '-') { return 'Undefined'; }
    var val = parseInt(i); // The value sent by OH is a string so we parse into an integer
    var days = 0; // Initialise variables
    var hours = 0;
    var minutes = 0;
    if (val >= 1440) { // 1440 minutes in a days
        days = Math.floor(val / 1440); // Number of days
        val = val - (days * 1440); // Remove days from val
    if (val >= 60) { // 60 minutes in an hour
       hours = Math.floor(val /60); // Number of hours
        val = val - (hours * 60); // Remove hours from val
    minutes = Math.floor(val); // Number of minutes
    var stringDays = ''; // Initialse string variables
    var stringHours = '';
    var stringMinutes = '';
    if (days === 1) {
        stringDays = '1 j '; // Only 1 day so no 's'
    } else if (days > 1) {
        stringDays = days + ' j '; // More than 1 day so 's'
    } // If days = 0 then stringDays remains ''
    if (hours === 1) {
        stringHours = '1 h '; // Only 1 hour so no 's'
    } else if (hours > 1) {
        stringHours = hours + ' h '; // More than 1 hour so 's'
    } // If hours = 0 then stringHours remains ''
    if (minutes === 1) {
        stringMinutes = '1 m'; // Only 1 minute so no 's'
    } else if (minutes > 1) {
        stringMinutes = minutes + ' m'; // More than 1 minute so 's'
    } // If minutes = 0 then stringMinutes remains ''
    var returnString =  stringDays + stringHours + stringMinutes
    return returnString.trim(); // Removes the extraneous space at the end
})(input)
have a nice day
You should be able to set a state descirption pattern like:
%1$td day %1$tH hours and %1$tM minutes
which will result in something like
Thx @Mherwege very good :+1:
@sebSmarthome and @Mherwege
Great! It works. Thank you very much. :+1:
You may change to:
  subtitle: "=props.UptimeTitle+':
    '+Math.floor(items[props.SystemUptimeItem].state.split(' ')[0]/1440) + 'd '
    + Math.floor((items[props.SystemUptimeItem].state.split(' ')[0]%1440)/60) +
    'H ' + Math.floor(items[props.SystemUptimeItem].state.split(' ')[0] %60) +
    'M'"
