List Item Widget for System info
SystemInfoListItemScreenShot
This is an UI List Item Widget to view the RaspberryPi System info with the Systeminfo Binding and reboot/shutdown system with the Exec Binding.
Only use with List Card with accordion and rich list items option set to true.
Support to use a light and a dark background.
Configuration parameters:
  • All title string
  • Icons - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
  • Visibility of Label item (Cpu, Memory, Storage, Swap, Network, Reboot, Shutdown)
items Systeminfo Binding
  • CPU Temperature item
  • System Uptime item
  • Cpu Load1 item
  • Cpu Load5 item
  • Cpu Load15 item
  • Memory Total item
  • Memory Used item
  • Memory Used Percent item
  • Memory Available item
  • Memory Available Percent item
  • Storage Total item
  • Storage Used item
  • Storage Used Percent item
  • Storage Available item
  • Storage Available Percent item
  • Swap Total item
  • Swap Used item
  • Swap Used Percent item
  • Swap Available item
  • Swap Available Percent item
  • Network Data Received item
  • Network Data Sent item
items Exec Binding
  • Reboot command switch item
  • Power off command switch item
Screenshots
Screen4
Standard Library List Card
Screen2
Configure List
Screen3
Changelog
Version 0.1
  • initial release
Resources
uid: frs_System_Info_list_item
tags:
  - list
  - system
props:
  parameters:
    - defaultValue: Raspberry Pi OH
      description: Title
      label: Title
      required: false
      type: TEXT
      groupName: header
    - defaultValue: iconify:mdi:raspberry-pi
      description: System Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: header
    - context: item
      description: CPU Temperature item
      label: Item
      required: false
      type: TEXT
      groupName: header
    - context: item
      description: System Uptime item
      label: Item
      required: false
      type: TEXT
      groupName: header
    - description: Hide Cpu label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: cpu
    - defaultValue: Cpu
      description: Cpu title
      label: Title
      required: false
      type: TEXT
      groupName: cpu
    - defaultValue: iconify:whh:cpu
      description: Cpu Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      description: Cpu Load1 item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      description: Cpu Load 5 item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      description: Cpu Load 15 item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
    - description: Hide Memory label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: memory
    - defaultValue: Memory
      description: Memory title
      label: Title
      required: false
      type: TEXT
      groupName: memory
    - defaultValue: iconify:fa-solid:memory
      description: Memory Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: memory
    - context: item
      description: Memory Total item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      description: Memory Used item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      description: Memory Used Percent item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      description: Memory Available item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      description: Memory Available Percent item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - description: Hide Storage label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: storage
    - defaultValue: Storage
      description: Storage title
      label: Title
      required: false
      type: TEXT
      groupName: storage
    - defaultValue: iconify:bi:device-ssd-fill
      description: Storage Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: storage
    - context: item
      description: Storage Total item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      description: Storage Used item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      description: Storage Used Percent item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      description: Storage Available item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      description: Storage Available Percent item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - description: Hide Swap label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: swap
    - defaultValue: Swap
      description: Swap title
      label: Title
      required: false
      type: TEXT
      groupName: swap
    - defaultValue: iconify:ic:outline-swap-calls
      description: Swap Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: swap
    - context: item
      description: Swap Total item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      description: Swap Used item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      description: Swap Used Percent item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      description: Swap Available item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      description: Swap Available Percent item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - description: Hide Network label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: network
    - defaultValue: Network
      description: Network title
      label: Title
      required: false
      type: TEXT
      groupName: network
    - defaultValue: iconify:bi:ethernet
      description: Network Icon - Use f7:iconName (Framework7 icon), material:iconName (Material icon) or iconify:iconSet:iconName
      label: Icon
      required: false
      type: TEXT
      groupName: network
    - context: item
      description: Network Data Received item
      label: Item
      required: false
      type: TEXT
      groupName: network
    - context: item
      description: Network Data Sent item
      label: Item
      required: false
      type: TEXT
      groupName: network
    - description: Hide reboot command label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: command
    - context: item
      description: Reboot command switch item
      label: Item
      required: false
      type: TEXT
      groupName: command
    - description: Hide power off command label-item
      label: hide
      required: false
      type: BOOLEAN
      groupName: command
    - context: item
      description: Power off command switch item
      label: Item
      required: false
      type: TEXT
      groupName: command
  parameterGroups:
    - name: header
      label: Header
    - name: cpu
      label: Cpu
    - name: memory
      label: Memory
    - name: storage
      label: Storage
    - name: swap
      label: Swap
    - name: network
      label: Network
    - name: command
      label: Commands
timestamp: Jan 5, 2022, 9:41:45 PM
component: oh-list-item
  after:  '=items[props.CPUTemperatureItem].displayState'
  icon: =props.SystemOHIcon
  style:
    --f7-list-item-after-font-size: 16px
    --f7-list-item-after-text-color: "=themeOptions.dark === 'dark' ? 'rgb(180,180,180)' : 'rgb(80,80,80)'"
  subtitle: '="Uptime: " + items[props.SystemUptimeItem].displayState'
  title: =props.SystemOHTitle
slots:
  accordion:
    - component: f7-list
        mediaList: true
        style:
          background-color: '=themeOptions.dark === "dark" ? "rgb(35, 35, 35)" : "rgb(247, 247, 247)"'
      slots:
        default:
          - component: oh-list-item
              action: analyzer
              actionAnalyzerCoordSystem: time
              actionAnalyzerItems: =[props.CPULoad1Item, props.CPULoad5Item, props.CPULoad15Item, props.CPUTemperatureItem]
              after: =items[props.CPUTemperatureItem].displayState
              icon: =props.SystemOHCpuIcon
              iconColor: gray
              style:
                --f7-list-item-after-font-size: 15px
                --f7-list-item-after-text-color: "=themeOptions.dark === 'dark' ? 'rgb(180,180,180)' : 'rgb(100,100,100)'"
                --f7-list-item-subtitle-font-size: 14px
                --f7-list-item-subtitle-text-color: "=themeOptions.dark === 'dark' ? 'rgb(180,180,180)' : 'rgb(100,100,100)'"
                --f7-list-item-title-font-size: 15px
                --f7-list-item-title-text-color: "=themeOptions.dark === 'dark' ? 'rgb(180,180,180)' : 'rgb(100,100,100)'"
              subtitle: =items[props.CPULoad1Item].state + " - " + items[props.CPULoad5Item].state + " - " + items[props.CPULoad15Item].state
              title: =props.SystemOHCpuTitle
              visible: =!props.HideCpu
              after: =items[props.MemoryTotalItem].displayState
              icon: =props.SystemOHMemoryIcon
              iconColor: gray
              style:
              subtitle: =items[props.MemoryUsedItem].displayState + " (" +  items[props.MemoryUsedPercentItem].displayState + ") - " + items[props.MemoryAvailableItem].displayState + " (" +  items[props.MemoryAvailablePercentItem].displayState + ")"
              title: =props.SystemOHMemoryTitle
              visible: =!props.HideMemory
              after: =items[props.StorageTotalItem].displayState
              icon: =props.SystemOHStorageIcon
              iconColor: gray
              style:
              subtitle: =items[props.StorageUsedItem].displayState + " (" +  items[props.StorageUsedPercentItem].displayState + ") - " + items[props.StorageAvailableItem].displayState + " (" +  items[props.StorageAvailablePercentItem].displayState + ")"
              title: =props.SystemOHStorageTitle
              visible: =!props.HideStorage
              after: =items[props.SwapTotalItem].displayState
              icon: =props.SystemOHSwapIcon
              iconColor: gray
              style:
              subtitle: =items[props.SwapUsedItem].displayState + " (" +  items[props.SwapUsedPercentItem].displayState + ") - " + items[props.SwapAvailableItem].displayState + " (" +  items[props.SwapAvailablePercentItem].displayState + ")"
              title: =props.SystemOHSwapTitle
              visible: =!props.HideSwap
              icon: =props.SystemOHNetworkIcon
              iconColor: gray
              style:
              subtitle: ="â–Ľ" + items[props.NetworkDataReceivedItem].displayState + " â–˛" + items[props.NetworkDataSentItem].displayState
              title: =props.SystemOHNetworkTitle
              visible: =!props.HideNetwork
              action: options
              actionItem: =props.ExecRebootCommandItem
              actionOptions: ON=Reboot
              item: =props.ExecRebootCommandItem
              listButton: true
              listButtonColor: green
              title: Reboot
              visible: =!props.HideRebootCommand
              action: options
              actionItem: =props.ExecPoweroffCommandItem
              actionOptions: ON=Shutdown
              item: =props.ExecPoweroffCommandItem
              listButton: true
              title: Shutdown
              visible: =!props.HidePowerOffCommand
Hello @sebSmarthome,
I have switched from 3.2.0 to 3.3.0.M5 and now to to 3.3.0.M6.
Basically I don’t see any problems. However, since 3.3.0.M5 I have a problem with the widget frs_System_Info_list_item (Marketplace).
Under 3.3.0.M5 and to 3.3.0.M6 the widget does not work anymore and I see a 0 in the lower left corner. If this is only related to this widget and with which function I can’t say. There is nothing in openhab.log.
Greetings Holger
It is working absolutely fine here with openHAB 3.3.M6
Sorry but unfortunately it does not work for me. As soon as I select Configure List → Accordion List appears a 0 at the bottom left.
grafik
Expanding the list does not work (worked under 3.2.0) I always see only the CPU uptime and the temperature.
I have already deleted the widget and restarted the Raspberry Pi. The widget then added again, no change.
Can you please post the complete yaml for the list card widget.
I just tried setting up a new widget on another page and it is definitely working as expected.
The YAML code inside the page.
component: widget:frs_System_Info_list_item
  CPUTemperatureItem: RasperryPi_CPUTemperature
  SystemUptimeItem: RasperryPi_SystemUptime
  CPULoad1Item: RasperryPi_Cpu_Load1
  CPULoad5Item: RasperryPi_Cpu_Load5
  CPULoad15Item: RasperryPi_Cpu_Load15
  MemoryTotalItem: RasperryPi_Memory_Total
  MemoryUsedPercentItem: RasperryPi_Memory_UsedPercent
  MemoryUsedItem: RasperryPi_Memory_Used
  MemoryAvailableItem: RasperryPi_Memory_Available
  MemoryAvailablePercentItem: RasperryPi_Memory_AvailablePercent
  StorageTotalItem: RasperryPi_Storage_Total
  StorageUsedItem: RasperryPi_Storage_Used
  StorageAvailableItem: RasperryPi_Storage_Available
  StorageUsedPercentItem: RasperryPi_Storage_UsedPercent
  StorageAvailablePercentItem: RasperryPi_Storage_AvailablePercent
  SwapTotalItem: RasperryPi_Swap_Total
  SwapUsedItem: RasperryPi_Swap_Used
  SwapUsedPercentItem: RasperryPi_Swap_UsedPercent
  SwapAvailableItem: RasperryPi_Swap_Available
  SwapAvailablePercentItem: RasperryPi_Swap_AvailablePercent
  HideNetwork: true
  HideRebootCommand: true
  HidePowerOffCommand: true
slots:
  accordion: []
The widget code from the marketplace as I downloaded it. Installed via the search in openHAB itself (binding).
tags:
  - system
  - marketplace:135253
  - list
props:
  parameters:
    - default: Raspberry Pi OH
      description: Title
      label: Title
      required: false
      type: TEXT
      groupName: header
    - default: iconify:mdi:raspberry-pi
      label: Icon
      required: false
      type: TEXT
      groupName: header
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: header
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: header
      label: hide
      required: false
      type: BOOLEAN
      groupName: cpu
    - default: Cpu
      label: Title
      required: false
      type: TEXT
      groupName: cpu
    - default: iconify:whh:cpu
      label: Icon
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: cpu
      label: hide
      required: false
      type: BOOLEAN
      groupName: memory
    - default: Memory
      label: Title
      required: false
      type: TEXT
      groupName: memory
    - default: iconify:fa-solid:memory
      label: Icon
      required: false
      type: TEXT
      groupName: memory
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: memory
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: memory
      label: hide
      required: false
      type: BOOLEAN
      groupName: storage
    - default: Storage
      label: Title
      required: false
      type: TEXT
      groupName: storage
    - default: iconify:bi:device-ssd-fill
      label: Icon
      required: false
      type: TEXT
      groupName: storage
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: storage
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: storage
      label: hide
      required: false
      type: BOOLEAN
      groupName: swap
    - default: Swap
      label: Title
      required: false
      type: TEXT
      groupName: swap
    - default: iconify:ic:outline-swap-calls
      label: Icon
      required: false
      type: TEXT
      groupName: swap
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: swap
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: swap
      label: hide
      required: false
      type: BOOLEAN
      groupName: network
    - default: Network
      label: Title
      required: false
      type: TEXT
      groupName: network
    - default: iconify:bi:ethernet
      label: Icon
      required: false
      type: TEXT
      groupName: network
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: network
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: network
      label: hide
      required: false
      type: BOOLEAN
      groupName: command
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: command
      label: hide
      required: false
      type: BOOLEAN
      groupName: command
    - context: item
      label: Item
      required: false
      type: TEXT
      groupName: command
  parameterGroups:
    - name: header
      label: Header
    - name: cpu
      label: Cpu
    - name: memory
      label: Memory
    - name: storage
      label: Storage
    - name: swap
      label: Swap
    - name: network
      label: Network
    - name: command
      label: Commands
  style:
slots:
  accordion:
        mediaList: true
        style:
      slots:
        default:
              action: analyzer
              iconColor: gray
              style:
              iconColor: gray
              style:
              iconColor: gray
              style:
              iconColor: gray
              style:
              iconColor: gray
              style:
              action: options
              listButton: true
              title: Reboot
              action: options
              listButton: true
              title: Shutdown
No,
the widget needs to be put into a list-card, otherwise it will not work.
I need to se the list card yaml code.
Sorry, the full code is attached.
  label: Test
  sidebar: true
blocks:
  - component: oh-block
    config: {}
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                    - component: oh-list-card
                        mediaList: true
                        accordionList: true
                      slots:
                        default:
                          - component: widget:frs_System_Info_list_item
                              HideNetwork: true
                            slots:
                              accordion: []
masonry: null
grid: []
canvas: null
please remove the slots and accordion line here. This is the difference I see to my working widget.
Thanks for the help. It works with that, no idea where that comes from. Have redone the page.
Is there a way to change the size of the icon (and the size of the badge) in the oh-list-item?
Great widget - thanks alot!!
Just like to add I had the same problems as Jeff - I had to manually delete the 2 lines with “Slots: Accordion: …”
Also I had an issue with displaying the items correctly, where I had to change every instance of “displayState” to “state” to get them to show correctly. Although I am not quite sure why, and what that actually changes?
