Hello. How can I get list of files in webview.
like this
but I have this error
How can I solve this issue
like this
google helped me) I need to change
webAppContext.setInitParameter("org.eclipse.jetty.servlet.Default.dirAllowed", "false");
to true. Where is this parameter
Try looking in var/lib/openhab2/config/org/ops4j/pax/web.config
. I didn’t see an entry like posted above so you may need to add this to the config and see if it works as expected. Note, you will need to stop OH before making a change to this file and I would also make sure you have a backup just in case.
tried. It doesn’t work( maybe in jetty.xml?
solved
/usr/share/openhab2/runtime/etc/jetty.xml
Set name=“directoriesListed”>true
