Hallo,
is anybody using Openhab for Load Management to control EV wallboxes? Is it working stable?
e.g. you have two 11kW wallboxes charging and your house can only provide 22kW, then the load management reduces the charging power if additional loads are switched on in the house. The goal is to not exceed the 22kW of the house.
I have seen a first script for this in the Go-eCharger binding documentation.
