Please excuse if the following is a bit garbled, but this is the first time that I am facing any challenges concerning OSGI module loading / iTests / and the GitHub CI build process.
I am doing some work on the Hue binding to add support for the Hue CLIP 2 API. The new code depends on the following two OSGI modules that are loaded by the OH core. And it works fine when the binding jar is running inside an OH operative system.
- an implementation of the ClientBuilder interface as defined in javax.ws.rs.client
- an implementation of the SseEventSourceFactory interface as defined in org.osgi.service.jaxrs.client
The Hue binding includes some iTests, and when I push my code to GitHub as an OH PR, the CI builder process complains something about lacking implementations of these interfaces that must be loaded in order to run the iTests.
I think I need to add some module names to the iTest .bndrun files in order to load those missing implementation modules, so that the iTests can run. ?? Is that correct? And if so, which are the modules that OH core would use (so that the iTests can use the same modules as OH runtime actually uses itself).
