Local addon not found (binding.modbus.stiebeleltron)
  • Platform information:
    • Hardware: Raspbarry Pi 5
    • OS: Debian
    • Java Runtime Environment: Java 17
    • openHAB version: 4.3.2
  • Issue of the topic: Local addon not found (binding.modbus.stiebeleltron)
I want to install the binding.modbus.stiebeleltron which is part of openhab-addons package, if is understand correctly. The package is installed and I also find the .jar file on the system (/var/lib/openhab/tmp/kar/openhab-addons-4.3.2/org/openhab/addons/bundles/org.openhab.binding.modbus.stiebeleltron/4.3.2/org.openhab.binding.modbus.stiebeleltron-4.3.2.jar).
Nevertheless, I cannot add the binding neither on the GUI nor on the openhab console. This binding shows up nowhere. How can I add this binding?
Welcome Christof.
The Stiebeleltron is an extension of the modbus binding. In openhab you will not see a separate binding, but only the modbus binding. That binding is extended with Things for your Stiebel Eltron.
So if you want to add Things, you create them from the modbus binding.
Correct, check the following:
Thank you for the fast answer.
