JVM
Java Virtual Machine OpenJDK Client VM version 25.172-b01
Version 1.8.0_172
Vendor Azul Systems, Inc.
Pid 7188
Uptime 2 minutes
Total compile time 1.562 seconds
Threads
Live threads 101
Daemon threads 56
Peak 128
Total started 171
Memory
Current heap size 42,184 kbytes
Maximum heap size 262,144 kbytes
Committed heap size 52,224 kbytes
Pending objects 0
Garbage collector Name = 'G1 Young Generation', Collections = 93, Time = 0.466 seconds
Garbage collector Name = 'G1 Old Generation', Collections = 0, Time = 0.000 seconds
Classes
Current classes loaded 12,619
Total classes loaded 12,644
Total classes unloaded 25
Operating system
Name Windows 10 version 10.0
Architecture x86
Processors 8*
Issue of the topic: I am really new to OPENHAB2 and I want to give it a try with my automation devices. However, for some reason I cannot make it work in my laptop. I am not really sure as in how to do it. I did the Prerequisites from the openhab guide for windows and downloaded Azul 8. However I keep getting once I open the localhost. I am not really sure where I messed up, so I’d appreciate any help you can bring!
“Access Error: 404 – Not Found
Cannot locate document: /”
System variable looks like this and I my openhab folder is located like this. “C:\OpenHAB2”
EDIT: This is also in the log
2018-08-05 23:40:36.878 [ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:425) ~[?:?]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:?]
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:351) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:319) ~[?:?]
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[?:?]
at org.eclipse.jetty.server.Server.doStart(Server.java:401) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl$1.start(JettyServerImpl.java:350) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:250) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:221) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:205) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerServlet(HttpServiceProxy.java:65) ~[?:?]
at org.openhab.core.internal.icon.IconForwarder.setHttpService(IconForwarder.java:36) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1556) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:261) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.updateController(Activator.java:352) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.lambda$scheduleUpdateFactory$2(Activator.java:291) ~[?:?]
