When making a thing for a temperature setpoint, like
<state readOnly="false" pattern="%.1f %unit%" min="0" max="80" step="0.5" />
is there a way to localize min/max/step?
Although I can display the units properly, I don’t see any way to localize the min/max/step of the configuration. This is more of an issue in paperUI, which uses these values. Ideally you would like one set for each unit. I looked through several bindings and couldn’t find any examples of localized min/max/step.
Thanks.
