Recently I started building a semantic model and hooking variables to it,
Unfortunately I made a mistake and assigned the same names to the item and the model. Since then I have no preview on the home screen of location and other data,
Of course, I changed the names of things and the model, I even completely destroyed the model, but I still have the same message
I don’t know how to make it disappear
Error!
A a loop has been detected in the semantic model: Taras is both descendant and parent of Taras. Please correct and refresh.
The problem Items should appear under Settings → Items. You can edit their values and Group memberships there. If not, use Developer Tools → API Explorer to query for and delete/modify the troublesome Item.
Just in case there is some confusion here I want to make it clear that the model is Items. It’s all Items. A Location is just a regular old Group Item with a special tag. Equipment is just a regular old Group Item with a special tag. So even if the semantic model is broken, you can get to everything under Items because they are all Items.
