I have setup mySQL in an openhabian environment. All is working ok.
However, I can’t find where all the tables are stored on the Raspberrypi as I would like to check how much data has been stored.
Any help would be appreciated,
thank
Chris
Login as root into mysql
mysql -u root -p
When prompted, supply the MySQL root password. Then from the MySQL prompt, select the data directory:
select @@datadir;
Output
| @@datadir |
| /var/lib/mysql/ |
1 row in set (0.00 sec)
(source)
Thanks Marcel,
I was able to do all the above,
but when i tried to list the contents of the /var/lib/mysql/ directory, permission is denied
You will need to become root
first:
sudo -i
Then you can list the contents of the directory:
ls -l /var/lib/mysql/
or to check the diskspace usage:
du -h --max-depth 1 /var/lib/mysql/
When your done being root
, simply type:
exit
And you are yourself again
