I am new so prone to newbie mistakes, while looking through logging I cam e across what looks like a bug in the log:set area. As you can see by the events below the help says to use DEFAULT as the unset level but it errors out.
openhab> help log:set
DESCRIPTION
log:set
Sets the log level.
SYNTAX
log:set level [logger]
ARGUMENTS
level
The log level to set (TRACE, DEBUG, INFO, WARN, ERROR) or DEFAULT to unset
logger
Logger name or ROOT (default)
openhab> log:set DEFAULT
Error executing command: Can not unset the ROOT logger
openhab>
so bug that I should report or newbie issue?
