- Platform information:
- OS: Linux Mint
- openHAB version: openhab2 v2.5.9-1
I’ve recently removed a motion sensor (used with Sonoff RF Bridge), including the Item & the MQTT Thing & relevant rule references. So theoretically, Openhab should no longer know about the motion sensor., however I noticed that while the motion was on my desk, I was still getting messages in the logs.
2020-09-24 16:41:07.569 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ‘EFCEEE’ not supported by type ‘OpenCloseValue’: No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.EFCEEE
2020-09-24 16:41:07.570 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ‘EFCEEE’ not supported by type ‘OpenCloseValue’: No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.EFCEEE
2020-09-24 16:41:07.571 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ‘EFCEEE’ not supported by type ‘OpenCloseValue’: No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.EFCEEE
2020-09-24 16:41:07.572 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ‘EFCEEE’ not supported by type ‘OnOffValue’: No enum constant org.eclipse.smarthome.core.library.types.OnOffType.EFCEEE
I’ve done some reading and also tried clearing the openhab cache (clean-cache).
Any idea why I’m still getting these errors?
NOTE: I only use PaperUI for my configuration
thanks
