I updated to last nights build of openhab2.
Do these errors mean anything in particular? Not sure if it is affecting anything, but wanted to check and see if there is some underlying issue.
2017-02-08 08:30:50.171 [WARN ] [thome.ui.internal.proxy.ProxyServlet] - Proxy servlet failed to stream content: java.net.ConnectException: Connection refused
2017-02-08 08:30:50.195 [WARN ] [thome.ui.internal.proxy.ProxyServlet] - Proxy servlet failed to stream content: java.net.ConnectException: Connection refused
2017-02-08 09:29:46.671 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
