elarge
(emik)
November 4, 2021, 8:30pm
#1
Hi all,
I have setup up a lot of rules and some of them get fired every second. Since OpenHab 3 RuleStatusEvents are fired on Info log level.
I have tried to remove them inside of the XML logger file log4j2.
But also after restart of OpenHab I have not succeeded yet.
Can anyone please help me with this?
Here is my file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
<Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<RegexFilter onMatch="DENY" onMismatch="ACCEPT" regex=".*(RuleStatusInfoEvent|RUNNING|IDLE).*"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i" name="AUDIT">
<Policies>
<SizeBasedTriggeringPolicy size="8 MB"/>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="WARN">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<Root level="INFO">
<AppenderRef ref="STDOUT"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<!-- <Logger level="INFO" name="org.openhab"/> -->
<Logger level="INFO" name="openhab.event.ItemStateEvent"/>
<Logger level="INFO" name="openhab.event.ItemAddedEvent"/>
<Logger level="INFO" name="openhab.event.ItemRemovedEvent"/>
<Logger level="INFO" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="INFO" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="INFO" name="openhab.event.ChannelDescriptionChangedEvent"/>
<Logger level="INFO" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="INFO" name="openhab.event.ThingAddedEvent"/>
<Logger level="INFO" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="INFO" name="openhab.event.ThingRemovedEvent"/>
<Logger level="INFO" name="openhab.event.InboxUpdatedEvent"/>
<!-- <Logger level="INFO" name="openhab.event.RuleStatusInfoEvent"/>-->
<Logger level="INFO" name="openhab.event.RuleAddedEvent"/>
<Logger level="INFO" name="openhab.event.RuleRemovedEvent"/>
<Logger level="INFO" name="openhab.event.StartlevelEvent"/>
<Logger level="INFO" name="openhab.event.AddonEvent"/>
<Logger level="ERROR" name="openhab.event.ItemStateEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ChannelDescriptionChangedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="INFO" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="WARN" name="org.apache.sshd"/>
</Loggers>
</Configuration>
apella12
(Bob Eckhoff)
November 4, 2021, 11:43pm
#2
So are the items you want to suppress in the openhab log or the events log? Also I think the recommendation is “Neutral” rather than “Accept”.
Bob
elarge
(emik)
November 5, 2021, 9:44pm
#3
Thanks for the fast reply! Actually I try to suppress it from the console log when executing log:tail. That would be most important. Is this the same as the events log?
apella12
(Bob Eckhoff)
November 5, 2021, 10:33pm
#4
I don’t use the log:tail so can’t say. I asked the question because the regex could be in the wrong location in the xml file for what you want to do. I’d add it to the events log. I believe a restart is required.
Bob
elarge
(emik)
November 14, 2021, 8:58pm
#5
Hi again,
after two weekends I am still not having any success. Do you knwo what is wrong in my configuration?
<Appenders>
</Console>
<Policies>
</Policies>
</RollingFile>
<Policies>
</Policies>
<Policies>
</Policies>
</Appenders>
<Loggers>
<Root level="WARN">
</Root>
<Root level="INFO">
</Root>
</Logger>
</Logger>
<Logger level="INFO" name="org.openhab">
</Logger>
<!-- <Logger level="INFO" name="openhab.event.ItemStateEvent"/>
<RegexFilter onMatch="DENY" onMismatch="NEUTRAL" regex=".*(RuleStatusInfoEvent|RUNNING|IDLE).*"/>
</Logger>
</Loggers>
</Configuration>
apella12
(Bob Eckhoff)
November 14, 2021, 11:16pm
#6
This is really not my area as I have most everything suppressed and a custom zwave and sony logger, but do have one regex filter for the openhab.log. It seems to me some of your entries are misformated and you don’t need the filter in the Console appender (because the comment line says it is not used), but I guess it can’t hurt. Maybe this will help anyway.
log4j2.xml (6.2 KB)
Bob
