The problem was from the fact that I created the bridge in the graphical interface and the things in the configuration file (".things"). Which resulted in double upset of the bridge. So I deleted the bridge in the GUI and added the bridge’s parameters in the configuration file.
I solved this issue on an upgraded OH3 installation with a method that was not mentioned above. There were two broker connections. One as a thing/bridge, and the other as a non-removable system connection under settings. The latter was making the errors, and I disabled it by setting Broker Host to blank, instead of 127.0.0.1.
Specifically: OH3 GUI => Settings => Other Services => MQTT system broker connection => clear the field Broker Host and Save.
I was having a similar problem. I noticed these lines spamming my log file…
2024-01-30 06:43:38.265 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.0.180'. Next attempt in 10000ms|
2024-01-30 06:43:38.267 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.0.180' with clientid 31F7042450214790|
Took me ages to work it out… in the end I did a recursive search for the IP address in the OpenHAB root folder. Turns out one of my Roombas hadn’t docked properly and was offline!
