- Platform information:
- Hardware: Raspberry pi4b 2GB
- OS: Openhabian 1.6.3 (32bit)
- Java Runtime Environment: Java 11
- openHAB version: 3.0.1
- Issue of the topic: Lot’s of Skip event subscriber logs
- Please post configurations (if applicable):
- Items configuration related to the issue > To much to count
My cpu load was rather high (around 0.7 - 1.2) lately (Cpu usage is around 5-10% sometimes spiking to 50%). So I wanted to investigate why this was. After disabeling enabeling bindings, I couldn’t pinpoint the reason. Nothing let the load drop. So I set the log to TRACE on org.openhab. When I do that, I see couple of hundred times a second these type of messages. I think this isn’t right, but I have the log on TRACE, so maybe that’s normal on Openhab 3.0 but i’m not sure.
The strange thing is, the messages don’t make sense. For instance it says:
->FILTER: openhab/items/Ketelwarmwater/state:Weerbericht
But the item: Ketelwarmwater and Weerbericht don’t relate to eachother in any way. Not in rules, not in binding, not in item files, not in Things, not in Groups, not even in persistance.
Does anyone know what these messages mean? Could it lead to the relative high cpu load?
2021-02-11 23:46:07.854 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:Weerbericht
2021-02-11 23:46:07.855 [TRACE] [ue.internal.handler.HueSensorHandler] - onSensorStateChanged() was called
2021-02-11 23:46:07.855 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.856 [TRACE] [ue.internal.handler.HueSensorHandler] - onSensorStateChanged() was called
2021-02-11 23:46:07.857 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:Habchanger
2021-02-11 23:46:07.858 [TRACE] [ue.internal.handler.HueSensorHandler] - onSensorStateChanged() was called
2021-02-11 23:46:07.859 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.860 [TRACE] [ue.internal.handler.HueSensorHandler] - onSensorStateChanged() was called
2021-02-11 23:46:07.860 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:RadioPrev
2021-02-11 23:46:07.861 [TRACE] [ue.internal.handler.HueBridgeHandler] - Hue sensor '83' added.
2021-02-11 23:46:07.862 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.863 [TRACE] [ue.internal.handler.HueBridgeHandler] - Hue sensor '85' added.
2021-02-11 23:46:07.864 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:Woonkamer_decrease
2021-02-11 23:46:07.866 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.867 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:sendFindPixel3
2021-02-11 23:46:07.868 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.869 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:System_pod_mode
2021-02-11 23:46:07.871 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.872 [TRACE] [ab.core.internal.events.EventHandler] - Delegate event to subscriber (class org.openhab.core.internal.items.ItemUpdater).
2021-02-11 23:46:07.873 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:KeukenAanwezig
2021-02-11 23:46:07.874 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.876 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:Manual_light_mode
2021-02-11 23:46:07.877 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.878 [TRACE] [ab.core.internal.events.EventHandler] - Delegate event to subscriber (class org.openhab.core.io.monitor.internal.EventLogger).
2021-02-11 23:46:07.879 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:sendFindPixel2
2021-02-11 23:46:07.881 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.882 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:RadioNext
2021-02-11 23:46:07.883 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.884 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:RadioStation
2021-02-11 23:46:07.886 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
2021-02-11 23:46:07.887 [TRACE] [ab.core.internal.events.EventHandler] - Delegate event to subscriber (class org.openhab.io.openhabcloud.internal.CloudService).
2021-02-11 23:46:07.888 [TRACE] [dule.handler.ItemStateTriggerHandler] - ->FILTER: openhab/items/Ketelwarmwater/state:sendSmartHomeNotify
2021-02-11 23:46:07.889 [TRACE] [ab.core.internal.events.EventHandler] - Skip event subscriber (class org.openhab.core.automation.internal.module.handler.ItemStateTriggerHandler) because of its filter.
Did some testing and removed everything from openhab, bindings, things, items, persistance, etc. then the messages disappear. The higher load is due too Grafana and Inluxdb. Still curious what those messages mean.
