2019-03-28 09:03:46.822 [vent.ItemStateChangedEvent] - systeminfo_computer_openHABianPi_cpu_load changed from 5.5 to 5.7
2019-03-28 09:03:46.831 [vent.ItemStateChangedEvent] - Raspberry_CpuLoad changed from 5.5 to 5.7
2019-03-28 09:03:46.858 [vent.ItemStateChangedEvent] - systeminfo_computer_openHABianPi_sensors_cpuTemp changed from 60.1 to 59.6
2019-03-28 09:03:46.862 [vent.ItemStateChangedEvent] - Raspberry_SensorsCpuTemp changed from 60.1 to 59.6
2019-03-28 09:03:47.888 [vent.ItemStateChangedEvent] - systeminfo_computer_openHABianPi_cpu_load changed from 5.7 to 5.2
2019-03-28 09:03:47.892 [vent.ItemStateChangedEvent] - Raspberry_CpuLoad changed from 5.7 to 5.2
2019-03-28 09:03:47.934 [vent.ItemStateChangedEvent] - systeminfo_computer_openHABianPi_sensors_cpuTemp changed from 59.6 to 59.1
2019-03-28 09:03:47.937 [vent.ItemStateChangedEvent] - Raspberry_SensorsCpuTemp changed from 59.6 to 59.1
and ervery sceond ther is a new entry. But I don“t want them.
The source of the logs are not directly from org.openhab.binding.systeminfo. If you want to keep the state of the systeminfo_computer_openHABianPi_cpu_load Item changing every second, but donāt want the event.log logging for it, you can do what Peter suggested, or check out this postā¦
Thank you all my logging files are now reduced from a wild torrent into a static lake.
Even understand how to re-open the flow or add missing statement; to be honest just an ordinary TECP
Thinks this method might be even mentioned at this point of the documentation (but in this case leave this discusion to the experts).
Can now concentrate on a error which was lost in the waves:
[ERROR] [org.eclipse.lsp4j.jsonrpc.RemoteEndpoint ] - Internal error: java.lang.IllegalArgumentException: URI has an authority component
But this is off topic so not asking to investigate this error, but sharing a know solution is off course very much welcome.
Solved: My URI ERROR was caused by settings of VSCode + Openhab extension see further post. Hope this is helpfull.
The binding isnāt logging that every second. You are looking at events.log. events.log is the EventBusās log. It logs all events that get put on the EventBus (except for updates). The song progress Item is changing every second so that getās logged to events.log. There is a way to filter out those lines from the events.log using openHAB - Filtering event logs. However, IMHO, you may as well just turn off events.log before neutering it by selectively filtering out events. Either itās a log of the events or itās not.
Is it possible to use something from the openhab.log in a rule to send me a message one this particular event occurs?
It“s a WARN message and not a item change in the events.log
I am having issues with setting up the configuration file so that only some bindings show their log entries. Currently my log looks something like this
2020-03-29 19:06:50.556 [vent.ItemStateChangedEvent] - NanoleafBrightness changed from 0 to 100
2020-03-29 19:06:51.391 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 23.0 to 24.0
2020-03-29 19:06:52.448 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 24.0 to 22.0
2020-03-29 19:06:53.517 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 22.0 to 23.0
2020-03-29 19:06:54.593 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 23.0 to 34.0
2020-03-29 19:06:55.649 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 34.0 to 22.0
2020-03-29 19:06:56.760 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 22.0 to 67.0
2020-03-29 19:06:57.801 [vent.ItemStateChangedEvent] - LatencyAsterix changed from 67.0 to 18.0
2020-03-29 19:06:58.808 [vent.ItemStateChangedEvent] - RasperryMemoryUsed changed from 747 to 746
In this example you can see that the network binding produces many entries. So I want to mute it. I tried to copy the configuration of the first entry but it didnt seem to work.
The example is showing ItemStateChangedEvent , I think these are logged by openHAB core (the event bus) not the binding, rule, or UI that caused the event.
Tinkering with binding logging therefore will not affect that.
Yes youāre right.
My question is if I can deactivate those ItemStateChangedEvent entries for some bindings. So for example I want to get the ItemStateChangedEvent entries from my weather binding and want to not get the ItemStateChangedEvent for the network or the spotify binding.
By now I understand why this didnt help me.
Do you understand my question and what I am trying to accomplish?
I have a openhab with rules on jython. And I find it a bit frustrating, that I need to actively look for errors in several logs files I have.
Can we come up with some appender configuration, which would filter only failure and error related messages? I would like to have this appender create a file per day, so then it would be very easy to see if my system was producing any errors that day.
So basically selecting parts of texts which were originated by errors, exceptions, failures etc. And it would be great not only to select only the line, but all the relevant text, like this:
13:01:27.902 [ERROR] [sr223.jython.Heating NORMAL schedule] - Traceback (most recent call last):
File ā/etc/openhab2/automation/lib/python/core/log.pyā, line 51, in wrapper
return fn(*args, **kwargs)
File āā, line 169, in heating_load_new_targets
File āā, line 58, in orchestrate
File āā, line 108, in load_d_variables
KeyError: āvarsā
Well, the first question is why do you have multiple files to look through? If having them in multiple files is a problem, put them into one file. By default you would only have two log files, openhab.log and events.log and errors and warnings never appear in events.log.
For one, thatās not how log4j works. It doesnāt save up stuff and produce a file at the end of the day. When a log statement occurs, it gets written out.
Secondly, log4j works by giving each part of the code, libraries, your Rules, bindings, stuff in the core, itās own log name. Then you can configure what gets actually written out where based on log level. It is possible to create a filter for a given logger to suppress certain log statements.
Therefore, to achieve what you are after and to preserve the logs as they exist now you basically need to do a copy/paste/edit of the entire log4j config and create a separate appender and set them up to additionally log out to this new appender just errors and warnings.
But in order to understand a given error you often need the context that is logged out at the INFO or DEBUG level immediately before the error. I donāt see how this could do anything but make it harder to debug a problem.
If all you want is to know whether or not errors occurred: grep 'ERROR\|WARN' openhab.log will give you a list of all the errors. You could create a cron job that runs grep 'ERROR\|WARN' | count and curls that to an OH Item every night. Thatās the ānumber of errors previous dayā count. When itās not zero you know you have a problem to debug, open openhab.log and search for the ERROR. Then you get to see the error in context and from there solve it.
Your proposal would result in just yet another file you will need to look at and search through in order to find errors.
