HI,
after the upgrade to 3.3.0 openhab opens the openhab.log but doesn’t write any data.
The rest of the log Files are not opened. The openhab functionality is OK!
Only log Files are missing.
Any suggestions, thanks for your help!
br. Christian
HI,
br. Christian
What is in your log4j2.xml?
As far as I am aware it should look like:
Thanks for the fast reply, I didn’t change the file after the upgrade.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
<Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/Archiv/openhab.%i.log.gz" ignoreExceptions="false" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="4 MB"/>
</Policies>
<DefaultRolloverStrategy max="5"/>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/Archiv/events.%i.log.gz" ignoreExceptions="false" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/Archiv/audit.%i.log.gz" ignoreExceptions="false" name="AUDIT">
<Policies>
</Policies>
<!-- Zwave log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/zwave.log" filePattern="${sys:openhab.logdir}/Archiv/zwave.%i.log.gz" ignoreExceptions="false" name="ZWAVE">
<Policies>
</Policies>
<!-- Airquality file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/airquality.log" filePattern="${sys:openhab.logdir}/Archiv/airquality.%i.log.gz" ignoreExceptions="false" name="AIRQUALITY">
<Policies>
</Policies>
<!-- ASTRO file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/astro.log" filePattern="${sys:openhab.logdir}/Archiv/astro.%i.log.gz" ignoreExceptions="false" name="ASTRO">
<Policies>
</Policies>
<!-- InfluxDB file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/influxdb.log" filePattern="${sys:openhab.logdir}/Archiv/influxdb.%i.log.gz" ignoreExceptions="false" name="INFLUXDB">
<Policies>
</Policies>
<!-- Persistance file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/persistance.log" filePattern="${sys:openhab.logdir}/Archiv/persistance.%i.log.gz" ignoreExceptions="false" name="PERSISTANCE">
<Policies>
</Policies>
<!-- MQTT file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/mqtt.log" filePattern="${sys:openhab.logdir}/Archiv/mqtt.%i.log.gz" ignoreExceptions="false" name="MQTT">
<Policies>
</Policies>
<!-- HTTP file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/http.log" filePattern="${sys:openhab.logdir}/Archiv/http.%i.log.gz" ignoreExceptions="false" name="HTTP">
<Policies>
</Policies>
<!-- KM200 file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/km200.log" filePattern="${sys:openhab.logdir}/Archiv/km200.%i.log.gz" ignoreExceptions="false" name="KM200">
<Policies>
</Policies>
<!-- Network file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/network.log" filePattern="${sys:openhab.logdir}/Archiv/network.%i.log.gz" ignoreExceptions="false" name="NETWORK">
<Policies>
</Policies>
<!-- SamsungTv file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/samsungtv.log" filePattern="${sys:openhab.logdir}/Archiv/samsungtv.%i.log.gz" ignoreExceptions="false" name="SAMSUNGTV">
<Policies>
</Policies>
<!-- Automower file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/automower.log" filePattern="${sys:openhab.logdir}/Archiv/automower.%i.log.gz" ignoreExceptions="false" name="AUTOMOWER">
<Policies>
</Policies>
<!-- Dash Button file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/dashbutton.log" filePattern="${sys:openhab.logdir}/Archiv/dashbutton.%i.log.gz" ignoreExceptions="false" name="DASHBUTTON">
<Policies>
</Policies>
<!-- Echo Control file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/echocontrol.log" filePattern="${sys:openhab.logdir}/Archiv/echocontrol.%i.log.gz" ignoreExceptions="false" name="ECHOCONTROL">
<Policies>
</Policies>
<!-- Broadlink file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/broadlink.log" filePattern="${sys:openhab.logdir}/Archiv/broadlink.%i.log.gz" ignoreExceptions="false" name="BROADLINK">
<Policies>
</Policies>
<!-- Homeconnect file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/homeconnect.log" filePattern="${sys:openhab.logdir}/Archiv/homeconnect.%i.log.gz" ignoreExceptions="false" name="HOMECONNECT">
<Policies>
</Policies>
<!-- Homekit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/homekit.log" filePattern="${sys:openhab.logdir}/Archiv/homekit.%i.log.gz" ignoreExceptions="false" name="HOMEKIT">
<Policies>
</Policies>
<!-- ICloud file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/icloud.log" filePattern="${sys:openhab.logdir}/Archiv/icloud.%i.log.gz" ignoreExceptions="false" name="ICLOUD">
<Policies>
</Policies>
<!-- MQTTGeneric file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/mqttgeneric.log" filePattern="${sys:openhab.logdir}/Archiv/mqttgeneric.%i.log.gz" ignoreExceptions="false" name="MQTTGENERIC">
<Policies>
</Policies>
<!-- iCalendar file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/icalendar.log" filePattern="${sys:openhab.logdir}/Archiv/icalendar.%i.log.gz" ignoreExceptions="false" name="ICALENDAR">
<Policies>
</Policies>
<!-- Openweathermap file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/openweathermap.log" filePattern="${sys:openhab.logdir}/Archiv/openweathermap.%i.log.gz" ignoreExceptions="false" name="OPENWEATHERMAP">
<Policies>
</Policies>
<!-- Wifiled file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/wifiled.log" filePattern="${sys:openhab.logdir}/Archiv/wifiled.%i.log.gz" ignoreExceptions="false" name="WIFILED">
<Policies>
</Policies>
<!-- TR064file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/tr064.log" filePattern="${sys:openhab.logdir}/Archiv/tr064.%i.log.gz" ignoreExceptions="false" name="TR064">
<Policies>
</Policies>
<!-- CarNet appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/carnet.log" filePattern="${sys:openhab.logdir}/Archiv/carnet.%i.log.gz" ignoreExceptions="false" name="CARNET">
<Policies>
</Policies>
<!-- PSA appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/psa.log" filePattern="${sys:openhab.logdir}/Archiv/psa.%i.log.gz" ignoreExceptions="false" name="PSA">
<Policies>
</Policies>
<!-- Renault appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/renault.log" filePattern="${sys:openhab.logdir}/Archiv/renault.%i.log.gz" ignoreExceptions="false" name="RENAULT">
<Policies>
</Policies>
<!-- SNMP appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/snmp.log" filePattern="${sys:openhab.logdir}/Archiv/snmp.%i.log.gz" ignoreExceptions="false" name="SNMP">
<Policies>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="WARN">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
<AppenderRef ref="STDOUT"/>
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<Logger level="INFO" name="org.openhab"/>
<Logger level="ERROR" name="openhab.event.ItemStateEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="INFO" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="WARN" name="org.apache.sshd"/>
<!-- Custom logger config goes here -->
<Logger additivity="false" level="INFO" name="org.openhab.binding.zwave">
<AppenderRef ref="ZWAVE"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.persistance.influxdb">
<AppenderRef ref="INFLUXDB"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.core.persistence">
<AppenderRef ref="PERSISTANCE"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.airquality">
<AppenderRef ref="AIRQUALITY"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.astro">
<AppenderRef ref="ASTRO"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.http">
<AppenderRef ref="HTTP"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.mqtt">
<AppenderRef ref="MQTT"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.network">
<AppenderRef ref="NETWORK"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.km200">
<AppenderRef ref="KM200"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.automower">
<AppenderRef ref="AUTOMOWER"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.samsungtv">
<AppenderRef ref="SAMSUNGTV"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.amazondashbutton">
<AppenderRef ref="DASHBUTTON"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.amazonechocontrol">
<AppenderRef ref="ECHOCONTROL"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.broadlink">
<AppenderRef ref="BROADLINK"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.homeconnect">
<AppenderRef ref="HOMECONNECT"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.icloud">
<AppenderRef ref="ICLOUD"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.mqtt.generic">
<AppenderRef ref="MQTTGENERIC"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.icalendar">
<AppenderRef ref="ICALENDAR"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.openweathermap">
<AppenderRef ref="OPENWEATHERMAP"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.wifiled">
<AppenderRef ref="WIFILED"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.tr064">
<AppenderRef ref="TR064"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.carnet">
<AppenderRef ref="CARNET"/>
</Logger>
<Logger additivity="false" level="INFO" name="io.github.hapjava">
<AppenderRef ref="HOMEKIT"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.groupepsa">
<AppenderRef ref="PSA"/>
</Logger>
<Logger additivity="false" level="INFO" name="org.openhab.binding.renault">
<AppenderRef ref="RENAULT"/>
</Logger>
<Logger additivity="false" level="DEBUG" name="org.openhab.binding.snmp">
<AppenderRef ref="SNMP"/>
</Logger>
<!-- End Custom logger -->
</Loggers>
</Configuration>
br. Christian
There is a lot of “custom” stuff in there. Maybe take a backup and replace with the GIT version and see if it helps?
I just encountered that my file org.ops4j.pax.logging.cfg is empty. Change date is the upgrade date.
br. Christian
Got my logs back! It was the empty org.ops4j.pax.logging.cfg.
It may be a bug during upgrade?!
br. Christian
