Got an error in configuration, which causes log to produce the warning:
2021-05-15 00:57:15.992 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '{"linkquality":60,"state":"OFF"}' not supported by type 'OnOffValue': No enum constant org.openhab.core.library.types.OnOffType.{"linkquality":60,"state":"OFF"}
This line makes no hint, which item/channel is a culprit.
Is there a possibility to make log post info of which exactly item/channel produces this warning? I suspect this is very simple, but I cannot find how.
P.S. This time I tracked the error source item by disabling all things, then enabling them one by one, until warning reappeared
from this you can workout that it is a switch type channel
and the offending MQTT payload offers further clues.
Maybe you have another channel looking at link quality, a matching value will tell you which Thing to look at for partner channels.
Or you might use a tool like MQTT.fx toidentify the source and topic.
Thank you for your reply, rossko57
If I understood you right, we have no available straightforward logger mechanism to see the named path Thing-Channel-Item for errors in log file at the moment?
