I’m dipping my toe into block libraries for reusing some more complex things. But struggling with what seems to be the basics. I’ve created a simple library with some JS, but it no worky, so I want to dump out some debug information.
How do I call logs in the block library? I’ve done a copy and paste job from a blockly rule:
logger.info('Item {{input:ITEMNAME}}');
But when this gets called I’m getting logger as undefined. Can anybody point me in the right direction? I’ve had a bit of a hunt around other people’s libraries, but I’m not seeing anybody doing this.
jdk.nashorn.internal.runtime.ECMAException: TypeError: Cannot read property "info" from undefined
at jdk.nashorn.internal.runtime.ECMAErrors.error(ECMAErrors.java:57) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:213) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:185) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:172) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.Undefined.get(Undefined.java:161) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$4812$918$\^eval\_.L:34(<eval>:36) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:655) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:513) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:527) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.javaadapters.org_eclipse_xtext_xbase_lib_Procedures$Procedure0.apply(Unknown Source) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:191) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
- Platform information:
- Hardware: x64/lots
- OS: Linux/5.14.21-150400.24.63-default (amd64)
- Java Runtime Environment: 11.0.19
- openHAB version: 3.4.4
