Hi!
I want to introduce a seperate logger / logging in my rules. In order to accomplish this I have read the manual, which says
The config file for logging is org.ops4j.pax.logging.cfg located in the userdata/etc folder (manual setup) or in /var/lib/openhab2/etc (apt/deb-based setup).
What is now the proposed way: Should I move / copy the default logging cfg to the userdata/etc folder and add there may additional logging settings? Or should I rather create a new cfg file in the userdata folder with just my additions?
Furthermore I want to get access to the logfiles via the sitemap. Is there any easy way to show the (last) logfile entries?
Thanks in advance!
Best Regards,
Sebastian
