Logging TCP to seperate file
I want to create a separate file for TCP.
I know how to create the separate file, yet I can’t seem to find the right name of the TCP binding for the logger.
I assumed it was “smarthome.binding.tcp” as indicated below, yet I’m receiving nothing in the newly created file.
# Logger - TCP
log4j.logger.org.eclipse.smarthome.binding.tcp = DEFAULT, tcp
# File appender - tcp.log
log4j.appender.tcp=org.apache.log4j.RollingFileAppender
log4j.appender.tcp.layout=org.apache.log4j.PatternLayout
log4j.appender.tcp.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j.appender.tcp.file=${openhab.logdir}/tcp.log
log4j.appender.tcp.append=true
log4j.appender.tcp.maxFileSize=10MB
log4j.appender.tcp.maxBackupIndex=10
It should be:
log4j.logger.org.openhab.binding.tcp = INFO, tcp
Also, take a look here: http://docs.openhab.org/administration/logging.html#defining-what-to-log
@Dim
That did the trick, thank you very much.
Squid
