Had some issues with some ZHC5010 wall switches I picked up some days ago. They included fine, but as they are not in the database, I was not able to set any association groups through habmin.
In order to receive useful notifications on key press (which is rather a convenient feature in a wall switch), I had to include my zway in the association group for the switch_binary command class.
I tried to power up the way server and use the expert UI to do this. no joy. Even though the necessary feature is there, it simply didnât work.
But then I checked the zway JSON API, and found out I could add the needed multi channel association group node there simply through a browser, and it worked. bingo. I am now able to receive switch_binary command classes.
Can you elaborate on what the Set parameters are again?
What is the Group, Node and Instance?
Also, after I installed the Zway.me software, I am having issues getting information about my nodes. Forcing an interview seems to do nothing. Did you do anything in particular to get all nodes identified correctly in the zway.me interface?
I got the zway.me softare to properly identify my devices by making sure my z-wave controller did not run in openHab. I did that by editing the Serial port to something other than what it should be, in other words, I forced it to fail.
I tried to stop the openHab service, but it seems that if you kill it, it will just respawn.
When calling the API, do you get a reply other than ânullâ? If I use the link you provided, substituting the ip and nodeid for my own installation, all I get in return is a ânullâ.
