Great - thanks. I finally got it working, following the directions you gave
Just got home, and upgraded to 2.1 and it works.
I have a few problems/questions that i hope you can help with.
It seams to be unstable/slow.
When i trigger a button, it turns on a led, but not always, and not instant. -
Can i download the .jar file, for the 2.1 version, and run on OH2 ?
If yes, do you know where. I simply canāt fint the location, for the file.
Mine is also a bit slow and I donāt know why, but it could be interesting to see if itās the same with OH2.
I am not sure if it will be enough to just reinstall the the newest z-wave add-ons found here: add-one download and move them to the addons folder, I think the latest configurations must be part of the z-wave add-one but I donāt know for sureā¦
Have a look here: Installing add-ons
Btw I added the last configuration to the device yesterday.
Thanks.
I donāt work.
I found the .jar file here : https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/lastSuccessfulBuild/artifact/bindings/org.openhab.binding.zwave/target/
But putting it into my addons folder, donāt do anything.
So i guess i have to wait for 2.1 to be released, until it will work on my production OH.
Unless @chris can tell me that iām doing something wrong ?
btw. @Thomas_Schlichting when you say that itās slow. It still works every time right ?
I think that my problem might be, that iām running my OH in a VM, and the usb key, is presentet thru a hypervisor.
but i canāt test that, until i move it to my Raspberry pi.
/Robert
Quick update.
I moved my USB stick to my Raspberry PI, running OH2.0 and installed the 2.0 z-wave binding.
It forund the FUGA switch, and now itās working perfect.
Iām not really sure i understand why, since i thought the logic was in the OH binding, and not in the stick.
But no matter what, i now have it running
Regarding the speed there are two issues I can see. Firstly during startup, if devices arenāt responding it will take a bit of time to resolve. Once this is complete things should be fast, however I have seen a log that indicates there might have been an exception that stopped the transaction processing thread. This meant all transactions in this log were timing out which delays things by around 2 seconds.
I donāt seem to see this issue so if anyone catches a log with such errors, please email to me.
Cheers
Chris
Thanks @chris.
After i switched to a Raspberry PI, the speed (stability) problem is gone.
I think it might have been related, to presenting the Z-Wave USB stick, to a VM, thru a Hypervizor.
/Robert
There are a few threads about how to manually install bindings - try a search on the forum. Unfortunately itās not so easy .
Probably we will have a 2.0.1 release soon and Iāll update the database for that release.
@chris Are you up to try and explain to me how to fix this in the configuration? - and how important is it?
Endpoint 2 has no command class linked to the basic class.
Endpoint 3 has no command class linked to the basic class.
Endpoint 4 has no command class linked to the basic class.
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/503
This just means you need to tick the ābasicā tick box in these endpoints in the command class that is linked to basic. This is either binary switch or multilevel switch.
Take a look at the specific device class for the respective command class - that should be a good indicator.
Yes. Tomorrow when i get home.
But how do i get the file ?
/Robert
Sendt fra mobil enhed
if you used apt-get to install openhab on linux you can find it in /var/lib/openhab2/zwave
I recently installed OH2, and am having issues with my ZHC5010. Since OH2 is all new to me, I find it difficult to see what you guys did to make the switch work.
Can one of you make a short guide, explaining the nessesary steps to make the switch recognized, and usable in OH2?
So i got mine working, at least for the relay one.
the other 3 reports the following :
2017-03-05 14:53:04.589 [WARN ] [.ZWaveBinaryToggleSwitchCommandClass] - NODE 3: Unsupported Command 1 for command class SWITCH_TOGGLE_BINARY (0x28).
2017-03-05 14:53:09.438 [WARN ] [.ZWaveBinaryToggleSwitchCommandClass] - NODE 3: Unsupported Command 1 for command class SWITCH_TOGGLE_BINARY (0x28).
2017-03-05 14:53:10.206 [WARN ] [.ZWaveBinaryToggleSwitchCommandClass] - NODE 3: Unsupported Command 1 for command class SWITCH_TOGGLE_BINARY (0x28).
Could this be due to the fact, that iām still running OH 2.0, or is this because of an error in my configuration ?
/Robert
I donāt think the TOGGLE_BINARY command class is implemented at the moment. Is this something thatās actually needed? It could be difficult to implement in OH as thereās no toggle concept (if I remember correctly?).
Iām not a 100% sure what you mean.
The physical contact, has 4 triggers.
1 of them, controls the relay.
The other 3 (in default configuration), triggers the error that i receive here.
All i want, is to be able to press a button, and make OH see that change, so that i can trigger something in OH.
Is this what you mean or ?
I mean that the error you see in the log means that the COMMAND_CLASS_TOGGLE_BINARY command class is not implemented. I suspect from your answer that you donāt need it since you can use the COMMAND_CLASS_SWITCH_BINARY class instead to turn the relay on and offā¦
So, I would just ignore the message in the log for now (I might reduce it to debug only).
