ottogj
(Gerrit)
September 30, 2015, 1:44pm
#1
There seem to be an issue with the defined ACTIONS of the Harmony Hub Binding Addon:
I have the following in the addons directory:
org.openhab.binding.harmonyhub-1.7.1
org.openhab.action.harmonyhub-1.7.1
org.openhab.io.harmonyhub-1.7.1
I can bind and control items without issues but the Actions does seems to have an issue when used in the rules e.g.
rule "TV Power"
Item swNetwork_TV received command ON
harmonyStartActivity("Watch TV")
The logfiles returns:
17:39:33.852 [DEBUG] [harmonyhub.internal.HarmonyHub:81 ] - HarmonyHub action is not yet configured - execution aborted!
Anyone else having this issue?
Thanks, Gerrit
digitaldan
(Dan Cunningham)
September 30, 2015, 2:01pm
#2
Can you try
sendCommand(HarmonyHub, “Watch TV”)
assuming your item is called HarmonyHub, and see if that works? This
indeed could be a issue with the action bundle, I don’t think it gets much
use.
digitaldan
(Dan Cunningham)
September 30, 2015, 2:48pm
#3
One more question, are you naming your hub in the configuration like:
“harmonyhub:HarmonyHubGreat.host=HarmonyHubGreat”
or does you config look more like this:
“harmonyhub.host=HarmonyHubGreat”
I’m using the logitech harmony hub binding and harmonyStartActivity() works for me.
I’m not at home yet though so can’t compare config.
ottogj
(Gerrit)
September 30, 2015, 4:02pm
#5
Thanks for your help guys. It was a silly mistake that the HUB got a new DHCP IP and binding defined in config was not valid anymore. Yeah… one can only smile and keep pushing forward
Hi Gerrit,
my router has a reversed ip function in dhcp. So my HarmonyHub always get the same ip. Maybe you can configure this in your router/dhcp too?
