In https://www.openhab.org/addons/bindings/logreader/
example.rules says:
rule "LogReader"
Channel "logreader:reader:openhablog:newErrorEvent" triggered
// do something
… which calls upon newErrorEvent; however, this is not defined as an item in example.items.
Do I need to define newErrorEvent (if it even exists) in items, or should the rule refer to lastErrorEvent?
[later edit] Also, I just noticed that filePath
to ${OPENHAB_LOGDIR}/openhab.log
is a `required** parameter in the thing definition. However, the example.things does not list it.
I have defined the thing as shown in the example, and it seems to work; hence, the “parameter required” field should change to “no”?!
