Logviewer Error message
(Vincent) #1
  • Platform information:
    • Hardware: RaspberryPi 3+
    • Java Runtime Environment: standard
    • openHAB version: 2.4
In my logviewer every minute an error messages shows and i don’t understand where it is come from.
This is the message: 2019-04-18 19:44:00.032 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.net.ConnectException: Connection refused
Can someone tell me what the problem is and how can I solve the problem
Many thanks in forward
(David Graeff) #2
You have a rule that uses “http” to get or push data. And that fails.
Fix the url of that http request.
(Vincent) #3
Thanks!
The problem was the url in the Horizon rule. I made a copy from openhab site (binding Horizon), but the url does not work :
sendHttpGetRequest(‘http://192.168.192.1:62137/DeviceDescription.xml
