You have to manually create the scripts, or download them from Ansible Galaxy or GitHub. Most common software has had some developer already create a Role for you so all you have to do is download it and run it. Once you get some experience, I find it takes less time to code it than to do it from the command line, especially for things that need to be done to more than one machine.
For example, I recently discovered that ssmpt is no longer supported on Raspbian Buster and msmtp is recommended. So I figured out how to install it and configure it from Google. Coded up the role to do all the steps (including uninstalling ssmtp). Then I tested it on one machine, fixed the bugs if there are any, and verify it worked. Then I run it again on all the machines. It took about 20 minutes to switch all 11 of my machines from ssmtp to msmtp. And now when I need to set up a new machine or VM, msmtp will just get installed and configured and I don’t even need to remember that I’m using msmtp.
It’s not a backup system. It’s not intended to be a backup system and I didn’t bring it up to be used as a backup system. I only brought it up to address the “tutorials” mention in the OP. You don’t need tutorials if everything you’ve done is already captured in an ansible playbook.
It absolutely does touch the core OS. But as I’ve said before, the whole idea of the OS being this separate thing on Linux is not correct. The “core OS” is really just the version of the Linux kernel + the thousands of base libraries + a pre-selected set of software that have been tested and known to work well together. All of that, including the kernel, can be updated by apt-get. But only within a given release of the distro. When they release a new version of the OS it’s a much bigger deal. There can be many breaking changes between the versions and the software may be wired together differently. Therefore they treat it as a wholly new and separate thing. Running apt-get update will not migrate you from Ubuntu 18.4 to Ubuntu 20.4.
and it is not always possible and pretty much never advisable to upgrade a distro like that in place. They always recommend a fresh install of the OS because an in place upgrade leaves a lot of cruft, always takes longer (for an RPi we are talking hours), and it often fails leaving you with a broken OS that needs to be reinstalled from scratch anyway.
So in the upgrade case using Ansible, you would install a fresh Ubuntu 20.4 (when it comes out), create your user (which is usually part of the installation process) and configure ssh (Ansible works through ssh). Then run the ansible playbook and it rebuilds the machine on the new OS.
It’s like openHABian only it supports anything, not just openHAB stuff.
If you only have a disk image, you are potentially stuck forever on that old and potentially unsupported version of Raspbian (or whatever) if for some reason the in place upgrade fails to work.
There is a little bit of up front learning of the syntax. Once you have that, it really takes no longer to code it in Ansible than it does to just type it by hand.
For example, here is my msmtp role discussed about above:
- name: Install msmtp
apt:
name: [msmtp, msmtp-mta, mailutils]
become: yes
- name: Create config
template:
dest: /etc/msmtprc
mode: u=rw,g=r
src: msmtprc
become: yes
The first task installs msmtp and related packages. The second task copies the config file I have as part of my role (I’m not going to show it as it has me password in it) to the destination machine.
That’s it.
Even something really complex like cloning a git repo and building the source code isn’t much more work than that.
Far less time than setting it up by hand on all of those machines and, in my experience, once you learn Ansible, less time than doing it by hand the first time. It’s really not that complex.
Probably my most complex role is my Mosquitto role, but that’s because I have it generate the self signed certificates and set up a user and password as part of the role. It combines around three different tutorials from three different websites. But as you can see, it’s a little long but very straight forward to understand what it’s doing.
- name: Create mosquitto user
user:
comment: 'Mosquitto'
createhome: no
shell: /bin/false
state: present
system: yes
become: yes
- name: Mount mosquitto from file share
include_role:
vars:
mount_mode: '0660'
cifs_user: "{{ share_user }}"
cifs_pass: "{{ share_pass }}"
cifs_domain: "{{ workgroup }}"
mount_user: "mosquitto"
mount_path: "{{ mosquitto_data }}"
mount_src: "{{ mosquitto_mount }}"
- name: Create mosquitto directories
file:
path: "{{ item }}"
state: directory
mode: u=rwx,g=rwx,o=rx
become: yes
become_user: mosquitto
with_items:
- "{{ mosquitto_data }}/config"
- "{{ mosquitto_data }}/data"
- "{{ mosquitto_data }}/log"
- name: Copy the prepared mosquitto.conf
copy:
src: mosquitto.conf
dest: "{{ mosquitto_data }}/config/mosquitto.conf"
mode: u=rw,g=rw,o=r
become: yes
- name: Install mosquitto cients, temporarily install mosquitto
apt:
name: "{{ item }}"
update_cache: no
become: yes
with_items:
- mosquitto
- mosquitto-clients
- openssl
- name: Install pexpect
pip:
become: yes
- name: Generate passwd file
expect:
command: mosquitto_passwd -c {{ mosquitto_data }}/config/passwd {{ mosquitto_user }}
responses:
'Password\:' : "{{ mosquitto_passwd }}"
'Reenter password\:' : "{{mosquitto_passwd }}"
become: yes
- name: Remove mosquitto
apt:
update_cache: no
purge: yes
state: absent
become: yes
- name: Recreate mosquitto user
user:
createhome: no
shell: /bin/false
state: present
system: yes
become: yes
- name: Does the CA already exist?
stat:
path: "{{ mosquitto_data }}/config/ca.crt"
register: mosquitto_ca
- name: Create mosquitto certificate authority
expect:
command: openssl req -new -x509 -days 1461 -extensions v3_ca -keyout {{ mosquitto_data }}/config/ca.key -out {{ mosquitto_data }}/config/ca.crt
responses:
'Enter PEM pass phrase\:' : "{{ mosquitto_ca_passwd }}"
'Verifying \- Enter PEM pass phrase\:' : "{{ mosquitto_ca_passwd }}"
'Country Name \(2 letter code\) \[AU\]\:' : "{{ mosquitto_ca_country }}"
'State or Province Name \(full name\) \[Some\-State\]\:' : "{{ mosquitto_ca_state }}"
'Locality Name \(eg, city\) \[\]\:' : "{{ mosquitto_ca_city }}"
'Organization Name \(eg, company\) \[Internet Widgits Pty Ltd\]\:' : "{{ mosquitto_ca_org }}"
'Organizational Unit Name \(eg, section\) \[\]\:' : "{{ mosquitto_ca_unit }}"
'Common Name \(e\.g\. server FQDN or YOUR name\) \[\]\:' : "{{ mosquitto_ca_fqdn }}"
'Email Address \[\]\:' : "{{ mosquitto_ca_email }}"
when: mosquitto_ca.stat.islnk is not defined
become: yes
- name: Create server key and cert
include_role:
vars:
key: "{{ mosquitto_data }}/config/server.key"
csr: "{{ mosquitto_data }}/config/server.csr"
crt: "{{ mosquitto_data }}/config/server.crt"
cert_country: "{{ mosquitto_ca_country }}"
cert_state: "{{ mosquitto_ca_state }}"
cert_city: "{{ mosquitto_ca_city }}"
cert_org: "{{ mosquitto_ca_org }}"
cert_unit: "{{ mosquitto_ca_unit }}"
cert_fqdn: "{{ mosquitto_ca_fqdn }}"
cert_email: "{{ mosquitto_ca_email }}"
ca_crt: "{{ mosquitto_data }}/config/ca.crt"
ca_passwd: "{{ mosquitto_ca_passwd }}"
ca_key: "{{ mosquitto_data }}/config/ca.key"
become: yes
- name: Get uid
command: id -u mosquitto
register: mosquitto_uid
- name: Get gid
command: id -g mosquitto
register: mosquitto_gid
- name: Run the eclipse-mosquitto docker container
docker_container:
detach: True
exposed_ports:
- 1883
- 9001
- 8883
hostname: mosquitto.koshak.net
image: eclipse-mosquitto
log_driver: syslog
published_ports:
- "1883:1883"
- "9001:9001"
- "8883:8883"
recreate: True
restart: True
restart_policy: always
state: started
user: 999 # TODO why can't I use the variable created above?
volumes:
- /etc/passwd:/etc/passwd:ro
- /etc/localtime:/etc/localtime:ro
- /usr/share/zoneinfo:/usr/share/zoneinfo:ro
- "{{ mosquitto_data }}/config:/mosquitto/config"
- "{{ mosquitto_data }}/log:/mosquitto/log"
- "{{ mosquitto_data }}/data:/mosquitto/data"
NOTE: There is some deprecated syntax in the above I’ve not bothered correcting yet.
Stuff in {{ }} are variables defined in another file. The only think unusual here is that I mount the mosquitto folder from a samba share using another role called mount-cifs. Over time I’m slowly replacing samba with NFS. When I do, I’ll have an mount-nfs role and call it instead.
Anyway, you should be able to scroll through that role and figure out what each one of the roles does. In fact, you could probably figure out the exact command line(s) that you would execute by hand for each task. It’s not that hard. In fact it’s far easier than developing openHAB Rules.
It does take some discipline though. No manual changes allowed. All changes, tweaks, config updates, etc must be done through Ansible. If not, then they will be lost when you need to rebuild that machine. That can be frustrating if you only want to change one word in a config file or the like. So you either need to do the change in Ansible or after you make the change remember to update the Ansible roles.
No. But does looking up the user task in the Ansible reference and typing:
user:
createhome: no
shell: /bin/false
state: present
system: yes
become: yes
take more time than looking up a tutorial for creating a new user (I forget, which is better adduser or useradd), looking at the man page to remember the arguments to make a system user with no shell or home directory and typing:
adduser --system --no-create-home --disabled-password --disabled-login mosquitto
And if you add in the work of writing that down somewhere so you don’t have to look it up again and remember what you’ve done then you’ve actually created more work for yourself in not using Ansible.
Yes.
Here’s the general flow if you want to install something new.
- Create a new role directory structure of your Ansible folder. I use
ansible-galaxy init roles/newprogram
for that. This is usually on some other machine. - Research the new program so you understand what needs to be done to install it (you have to do this anyway).
- Edit roles/newprogram/tasks/main.yml.
- Look at the Ansible reference docs to the Ansible equivalent for all of the commands that you need to run as discovered in step 1. Write the tasks as necessary into main.yml. Ansible is usually idempotent meaning you can rerun the same tasks over and over again and nothing will happen if there is nothing to change. This will let you build up the role step by step if necessary, letting you check that everything is working before moving on to the next lines.
