Hi there,
I have found lots of posts in regards to dimming HUE bulbs from a KNX switch. But I am searching for a solution that works the other way round: A HUE dimmer switch (the old remote) should control a KNX dimmer channel.
Since the binding only recognizes initial press, short press, long press and let go, I am assuming I need some kind of rule to make this work? Maybe some of the scripting gods here can help me out here with a good clue how to achieve that goal?
Thanks a lot!
Cu
Frank
