[SOLVED] Looking for a simple light grouping example
***found solution after posting. Doesn’t look like I can’t delete though.
Dimmer Light3_Brightness {
I have openhab2 successfully running and configured for several items. The struggle i am having is how to control 3 trad Fri bulbs and keep them in sync.
I am thinking I want to use groups, but I am not understanding the help docs on how some of this workks.
I was hoping someone had a simple example of this. Basically one dinner controlling brightness of three bulbs. I am sure once I get pointed in correct direction, it will all click.
Platform information:
  • Hardware: CPUArchitecture/RAM/storage
  • OS: what OS is used and which version
  • Java Runtime Environment: which java platform is used and what version
  • openHAB version:
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
I am glad you found the solution on your own, probably by reading the forum or the docs.
Can you post you solution so that it may help another new user in the future?
Here is the solution:
