Looking for tunable white LED down lights
The current trend seems to get ‘switchable’ white LED down lights, which is useless, when ‘tunable’ white and automation is desired.
I just googled for over an hour looking for tuneable white LED down lights, and could not find any… looking for 10-ish Watts; straight down, ideally low profile and no driver (optional).
Has anyone got a source to point me to?
You want musical lights???
24v and needs a driver but high quality
https://www.constaled.de/produkte/spots/constaled-spots-deeptunablewhite/
https://www.voltus.de/?cl=details&anid=cfc40bc12cbec393000220ea02911929
You want to adjust the colour. I had not seen tunable used in that context.
Have you looked at zemismart? They make a Wifi one that tuya convert worked for. But I also think you can wire up if needed to reflash
Yes, they hum either like “Let it be” or “Over the rainbow” :smiley:
Sorry, my mistake, it is spelled w/o and ‘e’. :slight_smile:
Thanks… and relative high cost (damn) :frowning:
I have designed my own LED driver board; 16-channels per 10x12 cm2 board, which makes any LED dimmable, and I can use single, dual, triple channels as I like, or four for RGBW.
