I started getting these errors earlier this evening. Not sure if it’s the Nest site or the binding. I guess the Nest site as nothing’s changed this end…
2016-01-09 23:21:16.230 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:21:16.234 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:22:36.981 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:22:36.985 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:23:57.876 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:23:57.880 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:25:18.872 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:25:18.875 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:26:20.295 [WARN ] [b.n.i.messages.AbstractRequest] - Method failed: HTTP/1.1 503 Service Unavailable
2016-01-09 23:26:20.297 [ERROR] [.o.b.nest.internal.NestBinding] - Error retrieving data model: service unavailable
2016-01-09 23:27:41.347 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:27:41.352 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:29:02.646 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:29:02.647 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
2016-01-09 23:30:23.524 [ERROR] [b.n.i.messages.AbstractRequest] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-01-09 23:30:23.526 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest: Could not get data model.
