Hi all,
I am certain I have read somewhere that their is known feature issue around do loop conditions not being checked and using a cached state rather than getting it fresh on each loop, but I cannot recal where I read it and even if its true I need a fresh way to deal with my se case so I have opened this thread to present options.
I am turning on a heater for a hardcoded amount of time and after the time expires I turn off the heater, 95% of the time that is it everything is great but sometimes the sonoff does not turnoff and rather than just advise us that the timer has expired I would like it to advise us that the heater did not turn off when it should have, that way a human will switch off the heater.
I have tried many ways to deal with this and found that the voltage is not being seen to have changed to 0 volts thus indicating that it has been correctly turned off. looking for improvements in the approach.
RULE
rule "Alexa bedroom getting dressed"
Member of EchoCmds changed to "bedroom getting dressed" or
Item rGettingDressed received command ON
logInfo("getting-dressed","BR1_Temp_Auto : " + BR1_Temp_Auto.state)
// record current temp control setting
val String AUTO_START = BR1_Temp_Auto.state.toString
logInfo("getting-dressed","AUTO_START : " + AUTO_START)
// turn off temp control
BR1_Temp_Auto.postUpdate(OFF)
// turn on heater
sendCommand(BR1_Heater,ON)
// start timer for ten minutes, then turn temp control to previous setting
// turn off heater
createTimer(now.plusMinutes(1)) [ | {
BR1_Temp_Auto.postUpdate(AUTO_START)
var Number Attempts = 0
//for (Attempts = 0; Attempts < cars.length; Attempts++) {
// logInfo("getting-dressed", "Turn off Bedroom heater, Attempt:"+Attempts.toString+" Voltage:"+BR1_Heater_Voltage.state.toString)
do {
createTimer(now.plusSeconds(3)) [ | {
Attempts += 1
sendCommand(BR1_Heater,OFF)
} while (BR1_Heater_Voltage.state!=0 && Attempts < 3)
if (Attempts >= 3) {
logError("getting-dressed", "3 failures turning off Heater")
if (BR1_Echo_Notify.state != OFF) {BR1_Echo_TTS.sendCommand('The getting dressed timer has expired but the heater has not turned off.')}
if (LR_Echo_Notify.state != OFF) {LR_Echo_TTS.sendCommand('The getting dressed timer has expired but the heater has not turned off.')}
if (BR4_Echo_Notify.state != OFF) {BR4_Echo_TTS.sendCommand('The getting dressed timer has expired but the heater has not turned off.')}
if (BR1_Heater_Voltage.state==0) {
// Announce getting dressed period has ended and heater has turned off.
if (BR1_Echo_Notify.state != OFF) {BR1_Echo_TTS.sendCommand('The getting dressed timer has expired')}
if (LR_Echo_Notify.state != OFF) {LR_Echo_TTS.sendCommand('The getting dressed timer has expired')}
logInfo("getting-dressed","expiration announcment complete.")
if (HO_Echo_Notify.state != OFF) {HO_Echo_TTS.sendCommand('The getting dressed timer has expired')}
logInfo("getting-dressed","rule exited.")
The rule above is just where it happened to be when I decided to reach out it is not the best way I have found so far.
Hopefully providing the whole rule helps with context but really its only a small functional block of code that needs to be modified (or so I think).
Regards
Paul
