OH2 offers myTimer.hasTerminated() , but it doesn’t work unless the timer actually exists.
Problem fixed and worked perfectly well! I had to change that section for the following:
tBlink = createTimer(now) [| // create a timer which is executed immediately
iBlink++ // count up (only available with int)
if(iBlink < 201) { // while less than 201 (i.e. 100 * 2 + 1)
gAllLights.sendCommand(if(gAllLights.state != ON) ON else OFF) // toggle gAllLights
tBlink.reschedule(now.plusSeconds(2)) // reschedule Timer in 2 Seconds
} else { // otherwise
gAllLights.sendCommand(ON) // switch ON
tBlink = null // and delete timer
Maybe you can explained difference between " createTimer(now,[| " and " tBlink = createTimer(now) [| ".
In fact I used that way to create timer seen in another thread without knowing exactly the difference. With the first version I had some log error related to an unhandled Exception.
2020-06-24 07:12:34.743 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 58 2020-06-24T07:12:34.721-04:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@13c28 (conditionalExpression: false)
} ] threw an unhandled Exception:
java.lang.NullPointerException: cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
Well, there is no difference between
tTimer = createTimer(now, [|
// foo
and
tTimer = createTimer(now) [|
// foo
But the former version is more clear about the fact, that the lambda (the part between [ and ]) is a parameter of the function createTimer().
