- Platform information:
- Hardware: Raspberry Pi 2B
- OS: Raspbian (debian) version 6
- Java Runtime Environment: Java SE Runtime Enviroment Version 1.8.0_65
- openHAB version: 2.4.0
- Issue of the topic:
I have a Raspberry Pi and a iC880a running a modified version of the pkt_logger from the Gateway repository of Lora-Net.
I just changed the output file and turned off the file rotation, so there is only one file generated.
That part just works fine. Now i want to get the temperature from the payload, once the file is modified.
In the end i want to have a text field on the webpage just to see the temperature value.
Is there any preconfigured Binding for those file operations? When not how do i get an item to show up on the Webpage.
Can the Exec Binding do that, when i have a shell script that checks if the fiile was modified?
