Good afternoon all. Fired up my OpenHABian box today and the main web portal won’t load. IP at port 8080 says it won’t connect, but I can hit the 9001 log viewer. Log viewer shows it should be started:
2019-08-13 14:48:50.823 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.93.113:8080
2019-08-13 14:48:50.826 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.93.113:8443
This log entry is from a couple hours ago, but the entire box has been restarted since then and I’m not seeing a start/stop/failed dashboard entry that’s more recent, even though I’ve rebooted (suggesting it hasn’t tried to start in a while, even though I’ve rebooted a few times).
I show the service is running.
Thoughts?
I did just discover this in the logs:
2019-08-13 14:54:17.521 [hingStatusInfoChangedEvent] - 'omnilink:controller:4b0b72e5' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
at org.openhab.binding.omnilink.handler.OmnilinkBridgeHandler.reqEventLogData(OmnilinkBridgeHandler.java:512) ~[?:?]
... 8 more
Caused by: java.lang.InterruptedException
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:2014) ~[?:?]
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2088) ~[?:?]
at java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:467) ~[?:?]
at com.digitaldan.jomnilinkII.Connection.sendAndReceive(Connection.java:244) ~[?:?]
at com.digitaldan.jomnilinkII.Connection.uploadEventLogData(Connection.java:653) ~[?:?]
... 8 more
